Question about LG Televison & Video
Screen has lines going across one half and the other half was solid black, can not change input device or hear sound, does make fuzz sound when first turned on....
    Sergeant:
    Champion:
  • 223 Answers
Sounds like the line output transformer is not soldered on the board properly or needs replacing. The quickest way to check for dry joints is if you tap the tv and the problem goes away then it needs soldering to the board properly. Otherwise sounds like a replacement line output transformer. Hope this helps.
Posted on Sep 29, 2008
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
HP5066 flickering
Return it to the dumpster. It is a lost cause.
May 03, 2017 | Televison & Video
Samsung 32" LED TV Purple Line Horizontally across top of screen
Can you please change the input device to some other you know, works? If you do not notice any problem there, look for the aerial cable going close to any power line or has interference from some other transmissions of any kind nearby.
Jul 30, 2012 | Samsung Televison & Video
I have a solid black line across my 32' Element tv with sound,
If the line is about an inch thick, it might be due to a bad CCFL in the panel.
Jun 09, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Marshall mg100hdfx loud fuzz and distortion and no guitar sound
Check your input (guitar signal).
Also, check your gain and volume levels.
Make sure that you have a reliable, steady, and clean power source as well.
If the problem persists, contact the store from which it was purchased. There are a lot of things that can go wrong internally with the cheaper Marshall models.
Jun 25, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Televison & Video Logo
60 people viewed this question
Computer Repairing
Computer Repairing
