Question about Epson ACULASER CX11NF All-In-One Printer
Epson cx11 outgoing fax problems
When sending outgoing faxes I will get a busy signal even before the number has completed dialing. This will happen even on the auto re-sends and I have a good dial tone when faxing starts. Any solutions?
    Scholar:
  • 78 Answers
This is not an issue with you unit, this is an issue with your phone line. get your service provider to check the line. also remove the line from your fax and put a standard phone on the end, try to make a call and see what happens. if the same result occures, there is an issue with the line and not the fax.
Gremlin11
Posted on Dec 10, 2008
I have a Brother fax machine. When I dial a number to send a fax, there is a noise on the speaker in addition to the fax dialing and it defaults into a busy signal. What should I do?
The number u are dialing is either busy or someting is wrong with the phone line thus not connecting to the other party. The fax set up may be confiqurated wronlgy.
Regards
Sep 28, 2010 | Brother Office Equipment & Supplies
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Feb 22, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Can send fax but cannot receive fax. cannot copy
With your cell-phone, dial the telephone-number for the FAX interface.
Does your cell-phone "ring", or do you get an "intercept" ("this number is not in service") or do you get a "busy" signal?
Does the FAX "answer" after one ring? two rings? three rings? does it NOT answer?
Dec 10, 2009 | Epson Office Equipment & Supplies
Problem: Busy/No Response on all outgoing faxes
Put the document you want to send into the transmit tray, pick up the handset, listen for a dial tone, and then dial the # on the keypad..
It should ring just like any other phone. When the machine on the other end picks up and you hear the tones, press the start button.
Anything other than fax tones on the other end, it is not your faxes fault.
Nov 05, 2009 | Brother IntelliFAX 2800 Laser Fax
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Aug 29, 2009 | Office Equipment & Supplies
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Can not send out faxes
You have to get your phone line checked out .
Apr 28, 2009 | Brother IntelliFax-2820 Laser Fax
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
Jan 23, 2018 | HP OfficeJet 6210 All-In-One InkJet...
Busy signal when trying to send fax
of course..is that phone line, by chance a high speed internet connection?
May 28, 2008 | HP PSC 950 All-In-One InkJet Printer
Outgoing fax never goes
Do you have the same problem with different numbers that you fax to? Are you usinga voip phone service? I use Vonage and have a lot of trouble with faxing. Call the number you are faxing to with a different phone and listen for a fax tone.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Epson ACULASER CX11NF All-In-One Printer Logo
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
