I have a Magnavox model CMWV405 VCR which wuddenly quit - There is no power stand-by light, and the maching still has a tapein it which I cannot remove. There is no power anywhere. I have tried it in several known working outlets with the same result. Anything I can do?
    Sergeant:
    Champion:
  • 223 Answers
If you are able to check for a blown fuse internally, otherwise it probably is a faulty component on the power supply board. If you are not capable of doing this please trust a competant technician. Good luck.
Posted on Sep 29, 2008
The display on my Magnavox zv457MG9 DVD/VCR Combo is blinking.
Fault at its main digital board [System control part]. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 25, 2017 | Magnavox Televison & Video
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
The light on my magnavox converter keeps flashing green then goes to stand by mode
mine is doing this too, i called Magnavox support and they aid it is an internal power issue and cant be fixed by troubleshooting, it has to be serviced. imo, probably cheaper to buy another.
Nov 06, 2012 | Magnavox (TB100MG9) Video Converter
Have a Magnavox DVD/VCR player Model MWD 2206A,
units like DVD's, have the tendency of malfunctioning if not used for quite sometimes.corrrect me if i'm wrong.but like automobiles needs tune-up, right?try power it on for some time, but not using it.if still not call a tech
May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox vcr/dvd combo--dvd's play about 1/3 of the way then quit
sounds like bad pick-up unit (optical eye). these will heat up and reduce the fm envelope signal causing the optical eye to not read disc info. not worth repair. (it may could use cleaning, but usually a dirty eye will effect the movies from the beginning not after warm-up. mch
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I need codes for my direct tv box and rca tv .vcr/dvd combo
MAGNAVOX ................................ 0247
DIRECTV .......... 0863 0864 0564 0763
................. 0963 0259 0260 0263 0962
....... 0664 0065 0265 0465 0765 0866
....... 0966 0367 0567 0362 0563 0765
Dec 27, 2008 | Philips PM3S Remote Control
Problem with philips magnavox vcr
Most Philips/Magnavox VCR uses "PL" to indicate that the unit is on Parental Lock. Push and hold the power button on the remote control and wait for the unit to power up. This should be within 7 seconds.
Additionally, most (but not all) Philips/Magnavox VCRs are sub-contracted to Funai. Pls try here for Funai downloads of user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 16, 2008 | Televison & Video
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
