WON'T COPME ON - Televison & Video
  • Eric Spears
    Eric Spears Sep 30, 2008
    Replaced fuse an soldered bad connection, still no power. Do you have to use remote control to turn on?
There is no standby light
Posted on Oct 01, 2008
    Sergeant:
    Champion:
  • 223 Answers
If you turn it on and providing the fuse is not blown in the plug there are usually two things wrong but without having it in front of me I can only give my best guess. The first thing is it might have blown the internal glass fuse, if so replace with one only of the same rating and no wrapping of foil around it lol. Otherwise there could be a fault on the power supply, if you are capable trace it yourself otherwise trust a competant technician. Hope this helps.
Posted on Sep 29, 2008
  • Paul Sep 30, 2008
    If the standby light is on then you should be able to turn it on by pressing one of the channel buttons to turn it on. If this still does not work try with your remote control and if you dont have one a universal remote usually will do provided you follow the instructions on how to program it to your tv, but instead of switching off the tv, it will switch it on when you have the right code or use the scan method of the remote. If the tv still refuses to turn on after all this suspecta faulty diode on the power supply board as its stuck in standby. Post how you get on.
Engine won't run
Cranks but won.t run, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine cranks but won start Troubleshooting tips
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
Troubleshooting and Fixing Car that Won Start
No Start Diagnostic Basics EricTheCarGuy
Mar 22, 2016 | Cars & Trucks
Won t start will not turn over no crank do have lights and battery
then I can only suspect the starter has failed .
Oct 24, 2015 | Cars & Trucks
Can you get that document that says i won ?
Of course FIXYA has no document whatsoever indicating you've won anything. What makes you think that you won something?
Did you go an email telling you that you've won something?
Bevare of a SCAM
Sep 14, 2015 | FixYa Service
Whirlpool WGD6200 won't start
When you say it won't start, do you mean it won't heat up or do you mean it won't spin?
Nov 07, 2012 | Dryers
Why does the "service engine soon" light appear on
you have an issue with vehicle. could be anything from loose fuel cap to failed catalyst/ cat convertor, which is very expensive. you need to know the code number to get started with diagnosing issue. get your self a small hand hels scanner from your local friendly auto parts store and scan for codes. some part stores may even scan it for you for FREE. nissan dealer will charge you arm and your leg to look at it. our dealership charges 1hr of labor to look at "service engine soon" light and diagnose it no matter if it takes 5 minutes to figure out or 45 minutes you will pay 1hr of labor which could be around $100 big ones. so get a scanner which goes for around $60 and scan it your self and this way you have a scanner for future if the light comes on again for something else. that light can copme on for number of reasons.
Oct 10, 2011 | 2003 Nissan Altima
Will not start even after ajump start lights copme on only when jumper cables are hooked up when the jumper cables are disconnected there is no power at all when the jumper cables are hooked up for about...
Have the alternator and battery checked. Startor may be flat, if it is, hit with a hammer until you get a new one. Recommend calling salvage places or junk yards for parts due to the year.
Sep 26, 2009 | 1995 Pontiac Grand Prix
Right rear brakelight wont copme on
the bulb will need to be replaced. It would be best if both are about the same age. If bulb is new, then the brake switch is faulty.
Sep 23, 2009 | 2001 Buick Century
1990 Diahatsu Charade cooling fan not going
The fan should only run when it gets hotter, if it does not copme on when hot then the fan is bad.. or its not getting power to the fan, the computer and relays and fuses connect it, I have just ran aq new wire from the bat. right to the fan to bypass all the ****.
Aug 16, 2009 | Daihatsu Charade Cars & Trucks
1992 buick park avenue
try that, can't remember if ABS codes copme through OBD diagnostic connector, worth a try
Mar 19, 2009 | 1991 Buick Park Avenue
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
