1st You download Webcam Driver.
A4tech pk835 camera pc
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: installer of A4tech PK835
http://www.a4tech.com/ennew/driver/CameraA.zip
If helped rate fixya
SOURCE: how can i download a4tech webcam coz i dont have installer?
If you are using Vista, you can extract the file from a zip by choosing a right button click of your mouse on the file when it fully downloaded from here and yes the download from the manufacturer website is in zip format. You will need to learn to use these compression routines like Winzip and Winrar if you intend to really use the internet for any practical purposes.
But more important then learning how to use a compression routine is learning how to use Windows Explorer, not the Internet Explorer. a master of Windows Explorer can do more or less anything he or she wants with computers going all the way back to 1988 or longer and it will give you some measure of self-assurance too. Just get yourself a decent how-to book from the library and concentrate on Windows Explorer. You will be amazed at what it allow you to accomplish but can be dangerous if not properly used.
SOURCE: install driver pc cameraPK835
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
Normal
0
Go to this site and select your product and download your
driver for your webcam.
http://www.a4tech.com/ennew/downloads.asp
Use the quick product locator then select “Web Cameras”
Then under “Downloads,” in the drop down, “Select”
the model number.
Also when it asks you for your Windows Operating Systen, be
sure to select the right one.
Then after completing the download do this.
Disconnect the Camera from the USB port and reinstall
the CD or Downloaded softwareprogram. When the program asks you to
connect the camera to theUSB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with.
Just installing the cameraon your computer does not set it up to broadcast on
messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video
to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
The camera and audio should function properly. Yourfriends
and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html)
Hopethis helps. Bud
Normal
0
the model number.
A. Skype Setup:
B. Yahoo Setup:
Hopethis helps. Bud
SOURCE: how to install my a4tech
A4Tech drivers are available from their WEB download site - click on this link and select your model WEBcam to download : -
http://www.downloadatoz.com/driver/item_a4tech-pk-635-webcam-driver.html
