Question about Refrigerators
Hi, i have an Bosch just over a year old and it has just recently started making a noise from the back of the unit. It sounds like a fan rubbing or rattling, it stops as soon as the fridge door is opened.
  • 943 Answers
Hi thanks for the question .It sounds like the fan in the fridge is rubbing locate the fan and clean out the obstacle thanks the appliance doc
Posted on Sep 29, 2008
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
I've got a Toshiba 52HM95 that's several years old. It's been making a grinding noise for a while. A few months ago I took the back off to investigate. The problem went away. But, now it's back. I have a...
The grinding noise sounds like it could be the fan blade hitting the housing. Have your verified that it is the fan that is making the noise? Does the fan feel loose or rub the housing when turned? Well you have already purchased another fan and have gone this far so I say continue dis-assembly if it is the fan. If you were looking to get a new TV then get one but don't trash this one. If you repair it you could sell it or give it to a friend/family member. A new 52in HDTV is not that cheap.
Jan 09, 2010 | Toshiba 52HM95 52" HDTV Projection...
I own an acer aspire M5100 about 1 year old, and just recently have been noticing quite a bit of noise at startup, not a great noise either, any advice? also when i slap the back of the computer the noise...
Check fans have not came loose make sure all graphic cards and so on are tight, make sure no wires have falling into fans or are rubbing them. hope this helps in some ways.
Dec 08, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Frigidaire FRS26R4A Vibrating Noise
Finally called a service technician. He said the compressor was bad and needs replacing. Fortunately, I'm in the 2nd - 5th year of my limited warranty so parts and labor are covered. He also said that the FRS26R4A is "junk" and it helps to support his family.
Jan 09, 2009 | Frigidaire FRS26R4A Side by Side...
Motor problem
hi,
I wrote to a person earlier about oiling one, now Im thinking she may be having the same problem you have, I will paste that info at the bottom, but sounds like your fan blade assembly has come loose and/or worked its way back down to the motor, study the fan blade assembly and look for an allen bolt or ring holding the assembly to the shaft, remove the ring or loosen the allen bolt , adjust the fan blade assembly so it doesent bind, oil the motor with regular 10w40 motor oil and dust the fan, these are good little fans and that company has been making those since the40's, also sending user guide link.
http://www.vornado.com/manuals/allcirc.pdf
J
Aug 04, 2008 | Vornado Circulating Fan
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
Jan 08, 2008 | Refrigerators
Lous Noise
It could be the blower fan is loose and needs to be tightened. If so, and you're handy, shouldn't be too difficult. Depends on the specific design.
Jun 16, 2007 | Kenmore 72175 Air Conditioner
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
