Question about LG Washing Machines
I have a lg intellowasher and its displaying a fault code "LE" and i've no idea what it means and have misplaced the manual. can anyone help?
  • gream_2002 Sep 29, 2008
    hi its a wm1280fdl if it helps. i stripped the back down to see if the le code which i believe means load error could be the bearings. there does seem to be a bad noise as the washer starts but it suddenly stops with the fault code. but if you spin the drum it seems to spin freely with no friction. any suggestions?
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Send me the model # and I'll see if I can send you the user guide download location.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
What does error code LE mean?
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Sep 20, 2010 | LG Washing Machines
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 14, 2010 | LG WM-2277HW Front Load Washer
I have an LE error code
yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Jan 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Error code LE
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Jan 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
" LE " displays
lg washing machine shows an error everytime i turn it on error such as pe
Nov 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hi I have a LG dishwasher model no:LD-12AW2 which is comming up on the display LE any idea what that means Thanks Andrew
Hi
Searched on google and found error code LE was a blocked filter cleaned tested ok
Sep 09, 2008 | LG Dishwashers
Washing Machines Logo
245 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
