ONKYO Speaker system model SKM-240S
I want to find out if I can connect the ref speaker (system) to my 42" Sony LCD TV set Model KDFE42A10
    Genius:
  • 1,148 Answers
YEH SHOULD BE BLE 2
Posted on Oct 05, 2008
My tv has no sound.
Make sure you don't have the mute feature turned on. Also, not sure about your particular model, but some of the older Olevia sets have external speakers that are mounted on the bottom of the set. The speaker wires are external and plug into a jack on the back of the set. If this is such with your set, check the speaker connections. Some TV sets also have an option which lets you disable you onboard speakers so that your audio out terminals are activated. This option is for those who choose to use their surround sound systems vs. the factory TV speakers which tend to be of cheap sound quality.
Sep 02, 2012 | Olevia LT42HVi 42 in. LCD Television
I NEED LAMP MODEL KDFE42A10
GOOGLE the model number with lamp after it and you will find dozens of places happy to sell you one or more.
Mar 18, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
When I turn the tv on it stays on for a few seconds, and then cuts off
is the power light or lamp light blinks? if its the lamp then replace it. your tv lamp model # XL-2400. check this link https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=600259&searchOperation=modelSearch&searchText=KDFE42A10
or if its the power light that blinks then turn off tv for 5 mins. unplug power cord for 1 min. try plugging the power cord directly into working wall outlet. if same, tv needs service. visit eservice.sony.com website to check service option
Dec 24, 2010 | Sony KDF-E42A10 42 in. LCD Television
I have Sony Grand WEGA KDFE42A10 42 in. rear projection TV that has colors issues where the RBG colors are not working correctly and everything is puke yellow? I tried resetting back to factory defaults...
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine you can find it here: http://www.discount-merchant.com/SONY-1-788-302-21-p/1175790.htm?Click=48173 . Have a blessed one!
Apr 28, 2010 | Sony Televison & Video
Bulb pop and picture is out
Here is a link for a replacement Philips lamp for your TV model. Don't worry if it doesn't say Sony on the box as Philips makes the lamps for Sony anyway. Pleas take a moment to rate my answer. Thanks...
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips+Lighting/F93087500RL/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KDFE42A10
Nov 23, 2009 | Sony KDF-E42A10 42 in. LCD Television
Large blue blob in middle of screen on my 42" sony tv model # KDFE42A10
check to see if your green and red lamps are lighting. if they are not then go to your convergence board and check to see if you are getting the right voltages. the voltages are written on the circuit board on some tv's. i believe that you are having problems with your convergence.
Nov 10, 2009 | Sony KDF-E42A10 42 in. LCD Television
TV won't turn on - green light flashes; then 6 red blinks
check your lamp, should be a lamp led lit on front of TV
Aug 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
NO SOUND FROM TV THROUGH THE SOUND SYSTEM SPEAKERS
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Replacing tv lamp
check your connections on your tv
Jan 17, 2009 | Sony KDF-E42A10 42 in. LCD Television
Lg tv and dvd
please connect the RCA wire yellow,red,white with TV set's output connections and other side connect with speaker systems input connections that's all
Nov 04, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
237 people viewed this question
Top Televison & Video Experts
