Question about Sharp AR-235 Copier
How do I change the header to accurately display our business name on outgoing faxes?
How do we change the header to accurately display our business name on outgoing faxes?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
http://www.sharpusa.com/files/cop_man_ar235_75.pdf (this is the opreation manual for the machine)
http://www.sharp.ca/manuals/ ( look for AR-FX4 which is the fax manual, this will better explain how to do this )
These particular machines are not the easiet to do.. I would suggest downloading the manual.. Below is from the manaul..
Press the FUNCTION key.
Press the arrow key to select "KEY OPE. PRG." and then press the OK key.
Enter your key operator code. (Usually 00000)
 As you enter the code, the hyphens (-) change to asterisks
 If you make a mistake, press the CLEAR key.
Press the up or down key to select "FAX" and then press the OK key.
Press the Up or Down key to select "INITIAL SETTING" and then press the OK key.
Press the Up or Down key to select "OWN PASSCODE SET" and then press the OK key.
Press the Up or Down key to select "STORE" and then press the OK key.
Enter your fax number with the numeric keys and then press the OK key.
Enter your name and then press the START key.
When the setting is completed, press the CLEAR ALL key.
 The key operator program ends.
The Panic Button method is a good way to mess things up?
Posted on Oct 23, 2008
  • Sharp Expert
  • 1,326 Answers
Have you ever heard of panic botton pushing..... Real you have to go into the Menu or Funcation setting and scroll thur it and find Fax settings. It should walk you thur it with no problem. Or look in the user manual that came with it. Or you may have to find it on-line. Do a search for Sharp faxs Manuals. Good Luck.... I normally just panic botton push till I find it... I work on way to mean to remember all of them.
Posted on Sep 30, 2008
Can you add a new fax no that shows in the header for outgoing fax?
To set Outgoing Fax Number/ ID follow the follwing steps: -
- Press FUNCTION, Press 7 (Set mode will appear on display)
- Press 1 (User Parameters Settings)
- Press Set repeatedly until display shows ID
- Enter your Number/ ID (max. 20 digits) by using the key pad
For further information you may refer to User Manual for Panasonic Panafax UF-585 Page 29
Hope it helps! Good Luck!
CreativeTECH
Feb 03, 2011 | Panasonic Panafax UF-585 Plain Paper Laser...
How do I change the name and fax number on the top of my outgoing faxes
The software that came with the printer will have a "setup" or "settings" icon. You can change it there.
If you can't find it or never installed it you can delete the printer software and re-install it and you can start from scratch with the new information you want.
Jan 27, 2011 | HP OfficeJet 6110 All-In-One InkJet...
We have taken delivery of a fax from within our business but need to change the header/business name that recipients see when receiving faxes from us
Press the Menu/set key, then down arrow untill initial setup, then press, menu/set, then down arrow to station ID, then menu/set. From here you can change the info you need to change.
May 08, 2010 | Brother IntelliFax-2820 Laser Fax
I need to change the name on outgoing faxes from my HP 6310 Officejet, but cannot find the information in the owner's manual. Can you help?
This "Fax header" information can be changed on the OfficeJet 6310 control panel:
1) Press the <Setup> button
2) Press 4, then press 1
3) Enter your personal or company name
4) Enter your fax number
You may have to use the numeric keypad to enter letters. The number of presses of the key changes the letter.
I hope this helps!
Mar 10, 2010 | HP OfficeJet 6310 All-in-One Printer...
How do you set/change the outgoing phone number on an HP Officejet 6110?
Hit setup. Arrow to fax setup (4). Hit ok.
Arrow to fax header, hit ok. Enter name, ok. THAT should bring you to the phone number.
Jul 17, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
Sharp AR-235 Copier Logo
155 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
