Question about Microsoft Xbox 360 Console
How do i change my mtu's or whatever for the belkin45g in order to get my xbox back online
  • Sparksmant Sep 29, 2008
    How do I change the mtu on a DLINK Adsl+2 router for xbox live
    Problem Solver:
  • 5 Answers
Posted on Sep 30, 2008
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
How to change my MTU on my router? So I can use xbox live..
Getting into a router might involve using a web browser and typing an address into it. Try opening Internet Explorer or whatever else you use and type in these in turn and hopefully one of them will bring you to a login screen:
The information should be in your router manual but if you don't know where that is, you can probably download one from the manufacturer's web site. If you need further help, make sure you give the make and model of your router.
please please vote.
Nov 12, 2009 | Microsoft Xbox 360 Console
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
Dont forget to rate the advice.
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
I have a xbox 360 that fails the mtu portion of the network connection. i have at&t dsl that is run through the phone jack to the router ( 2wire 2701hg-b) and from the router to the xbox. what do you...
check on the MTU settings of ur 2wire.
This are the steps to see what ur MTU setting is:
>connect a computer to the 2wire
>open Internet Explorer, Safari or Firefox
>enter this on the address bar:
>enter ur system password (in case u forget this, click on i forgot my password to get a hint)
>look for Advance in the column on the left
>click on configure services
>on the bottom, u shud see the MTU number
** i searched online and accdg to xbox tech support, ur MTU should be in the range of 1364 to 1500 **
>click on submit after u change the setting
just in case youve entered the correct MTU setting but it still does not work, u might need to contact either xbox or ur internet service provider.
Keep me posted on this one.
Dec 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Connection problems
MTU stands for "Maximum Transmission Connection". Some routers and/or network gateways are incompatible with Xbox LIVE, while others may be compatible but merely need to have a setting changed. If you compare your router to the list of routers at the following web address, you can confirm whether or not your hardware has been confirmed as compatible with Xbox LIVE by Microsoft:
Whether or not your hardware is listed as compatible, it would still be a good idea to check your instruction manual for the hardware you are using and see how (if possible) to change the MTU settings. Microsoft suggests that the MTU setting should be 1364. Using untested hardware or hardware not listed as compatible may still work, however, future updates to LIVE may suddenly make your hardware incompatible, as updates to LIVE and the Xbox console are made to work with the specifications of tested and listed compatible routers and gateways.
Aug 13, 2008 | Microsoft Xbox 360 Console
Xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Westell 6100 problems
we had the same issue. Here is how we fixed it. I had the xbox 360 plugged directly into the westell 6100 modem via ethernet cable. the mtu test failed everytime. I was extremely frustrated and called microsoft and verizon (dsl) about 10 times each and they kept giving me the wrong solution. (get a new modem, get a new server, pay us money and we'll figure it out etc...) Here is what a man at microsoft told me to do and finally it worked. Power cycle your equipment (unplug modem and xbox 360 for 30 sec.) then, plug in modem first and wait until all lights are back on. Then plug in xbox and run test. In my case mtu failed again. I was then instructed to go to my dashboard and restore xbox to factory default which I did and rerun the test. This time everything FINALLY passed. We were in business. I then decided to try connecting through my airport extreme router. I power cycled again starting with the airport then the modem then the xbox and ran the test and unbelievable as it sounds it all passed and my son is now sitting happily on the couch playing a game online with his xbox 360. This took away days of my life to get this simple thing done. I was given codes to change and change back on the computer, phone calls to everyone and the solution was so simple when you finally reach a knowledgeable person. Hope this will help save someone else the time I spent!
Oct 31, 2007 | Westell Wirespeed LiteLine 6100...
Microsoft Xbox 360 Console Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
