Got a QuickCam Chat- everything works except it wont record video-- when I click on 'record video' an error code pops up-- its not a windows error code- its a logitech one-- it reads Error code = 0x000001fe -that's it, all it says. Any advice???
does anyone know how to fix logtech webcam that wont record? it only takes pics, but I can skype with it..does anyone know how to fix logtech webcam that wont record? it only takes pics, but I can skype with it..
You can't post conmments that contain an email address.
Launch the Logitech QuickCam or Webcam software on your computer. Verify that you see yourself Logitech Webcam software window. Close the software window. Sign in to Skype. Click the "Tools" menu and select "Options." Click "Video Settings," check the "Enable Skype Video" and "Start my video automatically when I am in a call" boxes. Select your Logitech QuickCam from the drop-down list. Your webcam should display video in the window. Click "Audio Settings" if your QuickCam has a built-in microphone and select it from the microphone drop-down list. Check the "Let Skype adjust my audio settings" box in "Audio Settings" so Skype recognizes your microphone. Click "Save" to save the options for your audio and video settings. Skype will close the options menu.
Every now and then you are likely to run into Logitech webcams install errors and freezes resulting from system changes and updates
1Click the Windows "Start" button and click "All Programs."
2Scroll up and select "Logitech." Select "Logitech QuickCam" to launch the QuickCam software.
3Check the video record button. If it is recording, stop it to disable the streaming. Launch your other program such as Skype, AIM, Yahoo! or Live Messenger. There should no longer be a sharing issue. I don't know it would work,but have a try.
You do not say what OS you have but you need to check that the webcam mic is set as default.
Vista
TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
If you have an earlier OS you may have to access your hardware from your Control Panel
Normal
0
After you install Skype and have it operational with your
ID. Go to "TOOLS", click on "OPTIONS," Then go to
"Audio Settings" and click on it. Make sure both the Microphone and
Speaker's are correctly chosen.Then
"make a free test call." Wait till the voice tells you to
record. Then when finished talking wait for the test persons voice to
insure your audio transmission is working. Then go back to options and
test your video settings. Click on Video Settings and proceed to set up
you video camera. Also, you can visit this site for additional
information to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Normal
0
Double Click on this site http://www.free-codecs.com/download/AMCap.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20
AMCap is a small yet fully
functional video capture application compatible with Microsoft DirectShow. It
is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports
still captures to BMP, JPEG and PNG formats and it remembers your Video Input,
Video Standard and Video size settings from previous session. It has some nice
features like multimonitoring support, zooming, aspect ratio and deinterlacing
features.
AMCap is a small and effictive piece of software and definitely worth trying.
Hope
this will help.Bud
Try testing it, last time I checked skype has a test section, its hard to find, but its there. You just talk into the mic and skype records it. Then play back.
It is possible the mic isn't working.
Before you consider taking it back, make sure you follow the instructions to the letter.
