Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HL5067W power cycling
When I turn on the TV, the green lamp LED flashes a few times, the picture comes on fine, for about 10 seconds or so, then the TV turns off, then the starting sound chimes, and the picture comes back on for 10 seconds of so, and it powers off again and repeats. I have to unplug it to power it off. Any ideas? Thank you.
  • gawesq Sep 29, 2008
    Sorry, its a HL-R5067W.
  • gawesq Nov 26, 2008
    I thought that was it. Unfortunately, I was giving it crumpets. I'll try the scones.
    Problem Solver:
  • 7 Answers
I am having this same problem - power cycling - exactly as described. The lamp turns on and the picture looks good for the 5-10 seconds it is on (this makes me question all the comments I've seen online saying it is a bad lamp that needs replaced).
Problems started with green lines on analog channels and erratic behavior that included freezing and shutting off occasionally. Now, it is to the point where I get 5-10 seconds of picture, then it freezes and starts the power cycle 5-6 times, chiming every time it automatically turns on, before finally remaining off. I have removed the back, dusted off fans/components/etc, supplied additional fan for airflow, and made sure the blue switch in the back is down. Still having the same problem! Any help is appreciated!!
*My tv and I were on pretty good speaking terms leading up to these problems and I have it on a strict diet that has always worked. Any other suggestions?
Posted on Nov 17, 2009
  • Jason Burgoon
    Jason Burgoon Jan 27, 2010
    Ok. I went through the standard warranty process, which means they sent me a replacement bulb saying that was the issue. No luck...same power cycling. Finally they sent a tech out who took a look and said he needed to replace the digital board. So, 2 weeks later, the part came in and the repairman came back out to install it. Voila, I have a tv again. (This is the same fix the supervisor at the call center said it needed months ago...before they sent me the lamp)
    So...I would recommend having the tv's digital board checked. Especially if your tv is still under warranty, as it cost me $0.00 to fix. Chances are, they are still going to start by having you replace the lamp. Good luck!
It's a well known fact that Korean televisions are not fond of crumpets. I think that was probably the first warning in your Samsung manual.
Posted on Nov 28, 2008
It's simple. Your TV does not like you. Perhaps you need to speak kindly to it before you force it to watch BBC for hours. Buy it a scone.
Posted on Nov 24, 2008
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony Grand Wega KF50WE610 Video/Audio disappears every 1-2mins
Hello apharcha,
99.99% its the lamp. You may also have a faulty door, but thats kinda just 2% possibility. Change the lamp...its due anyway.
List Price $200.00
Part Number A-1606-034-B Description LAMP BLOCK XL2100U
Best regards
circuitcity
Jun 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
529 people viewed this question
Henry  Thomas
Henry Thomas
