Question about Talon Electronics - Others
My 91 eagle talon overheated then ceased
The temp guage went up really high, on my way trying to get home, the car ceased then would not start, what could be wrong with it
    Champion:
  • 242 Answers
It may have gotten hot enough to fuse the pistons to the cylinder walls. Loosen up all of the belts going to the harmonic balancer and hook a socket to it. Try to turn it in a clockwise fashion. If it doesn't turn, your engine is seized and will be a total loss. If it turns, some other problem exists.
Posted on Oct 24, 2008
Why won't my 91' Eagle Talon 2.0 Turbo start after overheating? I changed the thermostat, drained and added coolant.
Depending on how hot it got, you might have a blown head gasket or even a cracked head if it got really hot.
Jun 03, 2015 | Eagle Cars & Trucks
My 91 eagle talon won't get a spark it just cranks
try crank position sensor.cam sensors are mostly for monitoring misfires. cam sensor doesnt determine spark timing
Dec 17, 2011 | 1991 Eagle Talon
91 eagle talon problem
sounds like the high speed jet in the caburator is fouling,, service the carburator using a kit deigned for your car,,, the kit contains all the replacement parts for the carb..
Jun 01, 2010 | 1991 Eagle Talon
How come my 91 talon tsi awd 5spd wont start
Possible bad starter , low voltage in battery meaning dead battery or just bad and corroded connections at battery post and starter. Try cleaning connections and recharge battery if needed.
Nov 08, 2009 | 1991 Eagle Talon
I own a pristine '91 eagle talon tsi awd 5
check buscher racing.com or call them they know it all when it comes to talons and dsm's
Oct 29, 2009 | 1991 Eagle Talon
95 eagle talon was fine when i went to the store
You may be low on transmission fluid or the torque converter is going bad. Check automatic transmission fluid level with the car idling on a level surface.
Oct 03, 2009 | 1995 Eagle Talon
Car stalls in the middle of driving it
Is the temp guage reading high or are you just suspecting it needs to cool down? Could be thermastat bad or possible water temp sensor bad. Maybe water pump. After next time you run the car for awhile carefully touch the radiator cap and should be hot, if not then coolant is not circulating.
Jun 14, 2009 | 1995 Eagle Talon
I have a 90 eagle talon turbo fwd will a 91 tranny work in my car
yep if it has the same size engine.and all electrical shift hook up the same.
May 22, 2009 | 1990 Eagle Talon
'90 Eagle Talon- Won't start!
you got fuel and spark, check the third to the equation, air... maybe you have an obstruction, also if you have a compression guage check the compression. good luck ill check back.
May 02, 2009 | 1990 Eagle Talon
91-92 talon hard to nearly impossible to start
Just an idea, but I think that you are onto something with the temperature sensor. If overheating was the cause of the head gasket to go, then I would imagine it would've fried the temperature sensor also. That would make it nearly impossible to start. The sensor should be fairly cheap enough to replace. Probably wouldn't even through out a code. My Mother-in-Law had the same problem with her Saturn, changed the temp. sensor and BINGO. No more problem. You just have to make sure you get the computer temperature sensor, not the fan temp. sensor. There are 2 of them suckers. Believe it or not. Hope this can help "with your idea". Best wishes.
Jan 17, 2009 | 1991 Eagle Talon
Electronics - Others Logo
114 people viewed this question
Top Talon Electronics - Others Experts
Are you a Talon Electronics - Other Expert? Answer questions, earn points and help others
