Question about RCA RP5030 Digital Voice Recorder
Programming Dictaphone Connexions Phone
How would I go about programming c-phones using one dictator ID dictating low priority and high priority jobs? The way I have it now is where I have 2 dictator IDs, one programmed as an automatic high priority and the other ID for low priority and if the job needed to be rushed, they would press the 6 button on the keypad to rush the job.
I hope you can help me.
Thank you.
You should setup 2 different work types. Have the dictator select the work type prior to dictating the job. The higher priority work type should be sorted higher up in the pool script for Enterprise Express. If this is a Straight Talk, simply have the dictator select work type 2 (priority) and that job will come to you first. If you need help setting up a pool or a pool script please contact timtrent at hotmail dot com.
Posted on Nov 03, 2008
Dictaphone 1253 manual
Hello they have it
http://www.tvps.com/Products/Dictaphone-1253-Manual---Mini-Cassette-Portable-Dictation-Recorder__ECS-MANDI1253.aspx
May 04, 2014 | Dictaphone Audio Players & Recorders
Will Dictaphone Write work in Windows 7?
Hello yes it is. Walkabout Transfer Software, version 1.5.2, is required for the WA5220 portable. Backwards-compatible with WA5210/5215(DS) portables. Windows 7 compatible. For Dictaphone Digital portables and Trancription kits you can go to http://www.tvps.com/Departments/Digital-Dictation/Digital-Portable-Recorders/Dictaphone.aspx?sortorder=4&page=1
Apr 19, 2011 | Dictaphone Walkabout 5210 Digital Voice...
Which transfer program for dictaphone m5220 works with windows 7?
You can use either Walkabout Transfer or Walkabout Write found here:
https://isupport.nuance.com/OA_HTML/csksxvm.jsp?nSetNumber=13097
Also, if you connect the portable via USB to your PC, it'll connect just like a USB memory stick and you can use Windows Explorer to transfer your dictation from the 'DSS' folder.
Mar 01, 2011 | Dictaphone Walkabout 5220
Dictaphone use for Medical Transcription
You'll need a digital recorder (Dictaphone makes one - a Walkabout Model 5220). Transferring a recording from an analog (tape) machine to a PC requires a patch cord to hook it up to your PC, then some sort of software to record it while it's playing back.
May 12, 2010 | Dictaphone 1243 Handheld Cassette Voice...
How do I program the end button on my dictaphone 0421 machine?
Press the 'PROGM' key, and enter in the security code (if required), then press the 'KEYS' button. Then choose which button you want as your disconnect button and enter '5', then press the 'Select' key to store it and then press the 'Stop' button to exit key programming mode.
Hope this helps...
Sep 05, 2009 | Dictaphone 0000421-DPS Connexions Station...
Lost manual for dictaphone 2750
For transcribing, you'll need the machine (2750), the power supply, a foot control, and a headset (unless you use the machine's built-in speaker).
For dictating, you'll need the machine (2750), the power supply, and the microphone.
Mar 11, 2009 | Dictaphone 2750 Desktop Cassette...
Need a manual for the 0421 dps connexions station
I went to Google and entered Dictaphone 0421 + manual. Took me to a website titled FREE DICTAPHONE C-phone 0421/0424 manual. This lead to MT Stars, with link at bottom of page for manual download. It worked for me. I saved it into My Documents
Nov 25, 2008 | Dictaphone 0000421-DPS Connexions Station...
Dictaphone transcribe station model 420
Is there any way to turn volume higher on model #0421? Old model and I think the volume button is not working...
Jan 17, 2008 | Dictaphone Audio Players & Recorders
RCA RP5030 Digital Voice Recorder Logo
184 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
