Question about Dishwashers
Need Reset code button sequence
I have a dishwasher that only blinks the lights. I can't get it to work. The last time this happened I called around and found out from someone that I needed to push three buttons to reset it, when I did this... it worked. Now, since I didn't write the button sequence down I can't get it to work again. I have called around but no one will tell me unless I pay alot of money for a "service fee."
PLEASE HELP
  • mcfarlal Oct 14, 2008
    same problem but after reading the entire manual it does not address the sequence code for resetting the controls.
    Please help.
  • peterdewolf Apr 08, 2009
    Having similar problems, had to replace the control board on mine as it blew ( bla kened contacts inside it ), and none of the programme lights illuminate after the replacement, the product literature search for my model returned no results at all, seems there is no manual for my model, ADP8322. Can you offer any advice?
    Pedero
  • 172 Answers
Hi ez_drummin02,
The following link will give you step by step instructions for unlocking the controls on your dishwasher. Simply get your model number off your dishwasher and enter it into the box. The owners manual will tell you how to reset the board and locks if you have engaged the lock. http://shared.whirlpoolcorp.com/product_literature/search.jsp
Hope this will help.
Mike
Posted on Sep 30, 2008
Clean light blinks 7 times, pauses, then blinks 7 etc.?
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 25, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
Clean light is blinking, when you shut door and push start cycle nothing happens
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
My newer model dishwasher has locked up. Clean LED light continues to blink. Any ideas? This happened once before and a sequence was given to me that I no longer had :(
Kevin
Mar 07, 2011 | Dishwashers
Our Kenmore Elite Dishwasher has a blinking green light next to the clean cycle. It won't reset. We changed the motor and this has been going on ever since. Do you know what we need to do to fix it....
Hello
Blinking green light can be reset by following two buttons in sequence: press HIGH TEMP WASH-HEATED DRY buttons in sequence around 3-4 times so that the control reset itself. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Kenmore Elite 45986 Front Load Washer
Blinking Green Light
Here's what I could find on the your error code:
A blinking clean light that flashes 7 times and cannot be reset, occurs when the electronic control does not detect a water temperature increase during the main wash. This could be an indication of a failed heating element, in line thermostat, electronic control board and/or wiring. This problem can also occur if the main wash pump becomes clogged and it not spraying sufficiently. I hope this helps you.
PS A faulty door latch can also cause this error code.
Jun 23, 2008 | Dishwashers
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Clean ligh is blinking
youll need to remove the bottom acess panel of d/w there should be an extensive trouble shooting guide tapedto back of panel in a sleeve, lotsa good stuff in there. depending on buttons its going to repuire pushing a sequence. "
sani-rinse---heated dry--sani rinse--heated dry.
it will enter a diag mode "all lights will light up" wait a few secs and then cancel cycle .. if happens a again or with frequency, then call a servicer, you have a problem, first time chaulk up to a fluke
Mar 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 66516032400 Dishwasher
On another website, we found a reset code that works for our Kenmore, which I think is the same as yours. Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds).
Dec 05, 2006 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
462 people viewed this question
Top Dishwashers Experts
