Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Aio software not found
Every time i start pc this window pops up saying aio software not found put cd in and hit ok then on other line it says source 1 or to brows nothn works
  • 102 Answers
Restore to a point when your system worked
Posted on Oct 31, 2008
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
How to install ms word 2007?
put disk 1 in cd, and start installing. here will be a window that will aks u what components u want to install., for instance, word, excel, etc. put a check next to word aND hit the ok button, follow through wuith your folder selection and instal. if u have further issues plz drop a line cheers pk
Jan 15, 2011 | Microsoft Office Professional 2007 Full...
I just had it from the shop and when I try to install the WD SmartWare Software, a pop up window apears saying "Windows can not find C:\ Program Files (x86)\ Western Digital\ WD SmartWare\ Front Parlor\ WD...
restart the PC, do not plug the device. now insert the software disk in CD rom. Plug in the device. lower right tray, toy will see found new hardware. now doubble click on it and then start installing diver from the CD rom by clicking and pointing next inside the intall hardware pop up menu. after installation, it will ask for restart. do it and then it should work.
cheers!
Sep 08, 2010 | Western Digital My Passport Essential SE...
Found new hardware bubble pops up then mouse and keyboard freze
disconect all the things that is connected to the pc and do them one at a time
Mar 12, 2010 | Dell OptiPlex SX280 PC Desktop
What the hell is AIO software NPI?
ok i hope this solves your problem... the AIOsoftwareNPI is found in HP all-in-one printer CD.. put your HP all in one CD installer into CD room. restart your computer, after the boot it will automatically install the AIOsoftwareNPI.. if it doesnt work uninstal the printer and thro it out the window as you suggested
Jun 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Windows not Starting Correctly
Hit F12 on startup and then put your Dell system disk in so it will boot from the CD.
When you get the startup, you will be prompted to see if you want to repair with the recovery console. Hit R and wait until it asks for the installation you want to repair. The option #1 should be windows, so hit #1. When it asks for the password, hit Enter (I hope you don't have an admin password, 'cause that's what it is looking for. If you hit enter and you get a c:\windows> prompt, type in the following:
chkdsk /r
After the scan runs, Windows should start. If not, let me know and we can do other stuff.
Apr 19, 2009 | Dell Dimension 2400 PC Desktop
My Toshiba Satellite A215-S7413 laptop randomly goes to a blue screen with lots of white writing on it. I never have time to read it because it goes away so quickly. After the screen goes away it restarts...
Try going to Start - Run.
Type sfc /scannow in the run line and hit enter or click ok.
A dialog will pop up that says "Windows File Protection"
Allow this to run and insert the Win XP CD if requested.
Hopefully this will resolve your issue!
Jul 14, 2008 | Toshiba Computers & Internet
Start up problem
Download the "windows Installer cleanup utility" from microsoft --
After installing it on your computer, go to it from your programs menu and select AiO software NPI ... from the list of programs
presented. Hit the button to remove, don't worry about the pop up window that says you had a system error, just agree with it.
Feb 08, 2008 | Computers & Internet
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Problem installing the driver
Mine did the same thing - just ignore it and click ok - it will work believe me - just do it and it'll work.
Sep 12, 2005 | Creative Labs PC-Cam 550 Digital Camera
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
Seeker5211
Seeker5211
