Wireless adapter hi i have the same problem as you had with the amilo wireless button. did you fix this and if so how ive tried everything. Thanks
Hello, i have a fujitsu computers siemens amilo LI2727 i cannot turn on the wireless button can you please advise me on hoe to do this please Regards Debbie
Go to setting within your IPAD and look for wireless setting... there should be a check box there to enable your wireless...
Apr 20, 2011 | Fujitsu Siemens (IPAD142-RFI) (IPAD142RFI)...
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
Our internet is working fine with everything except my xbox. I either cant connect to xbox live or i cant stay connected. ive tried everything i can think of to fix it.
First of all, the wireless thing for the Xbox is a waste of money, when i had mine, it would always lose connectivity. Anyway make sure the device is not next to anything that gives off frequencies as that may cause the connectivity issue (microwaves etc....)
Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
Where is the wireless switch for the amilo 2000. I have pressed all buttons and it wont come on
You can go to the network adapters, right click on the wireless and enable
control panel / network adapters
Sep 04, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
AMILO LI 2727 cannot attach to my (or any other) wifi network since upgrading to windows 7
First Try This
Right click on the Computer desktop icon > Manage > Device Manager > Network adapters > right click on your Wireless Network adapter > Update Drivers Software...
If the Windows was unable to find drivers: go to the manufacturer website of your netbook > find your netbook model > download and install drivers for Wireless adapter
OR
You can try this solution:
Copy and paste the below text in to a text editor, save it and give it any filename with the extension .vbs, eg wirelessstart.vbs and copy a shortcut to your startup folder:
Set WshShell = WScript.CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("C:\Program Files\Launch Manager\WisWBSet.exe")
do while WshShell.AppActivate("Wireless Status Option")=False
WScript.Sleep 100
loop
WScript.Sleep 100
It would be better that you restart the system after doing that.
And Thanks.
Mar 31, 2010 | Fujitsu AMILO PC Laptops
Ive just got an xbox 360 adaptor for xbox live and the light is still on red on the back of the xbox live adaptor, how do you get it to a green light beacuse ive tried everything. many thanks cameron
You need to first set up your connection...the red light indicates there is no connection....you need to make sure your internet has a wireless network and u need to selct ur network from ur network settings in xbox360.
Mar 01, 2010 | Microsoft Wireless Network Adapter Xbox...
Wireless 360 Network Adapter won't turn red
This can actually happen quit a bit but it sounds to me like the usb jack may be dieing or not producing enough power. This can be caused if for instance you use wired controllers. Have you tried using the front usb ports.
Oct 12, 2009 | Microsoft Wireless Network Adapter Xbox...
Connection to wireless
There is any wireless adapter showing in the control panel.
According to the laptop specs, this laptop did not come with wireless capability. You need to purchase a wireless notebook adapter for it or us it with a network cable.
See the specs on this link:
AMILO-D-1840-FUJITSU-SIEMENS-Laptop-220304">http://www.twenga.co.uk/specs-AMILO-D-1840-FUJITSU-SIEMENS-Laptop-220304
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 07, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Wireless hotkey not working
i belive that when your computer boots you press F2 and the wireless card is automatically turned on
Mar 21, 2008 | Fujitsu (S26391-F2494-L100) Bluetooth...
Fujitsu Siemens Amilo Pro V2000D - No Internet?!?!?!?
http://support.fujitsu-siemens.com/com/support/index.html
and then into the search box AMILO Pro V2000
and you should come to drivers and download section press that one and then select youre operating system
and then you choose panel and download the launch manager which with you can make the wlan to start with system..Huh..FINLAND RULES
Jan 30, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
79 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
