Question about Uniden BC72XLT Handheld Scanner
BC72XLT Do you add new freqs to pre-existing bands already labeled as Pol, Ham Fire etc. or do you set up a new set of bands? Can you get it to jump from band to band automatically (ie from ham to pol) when on scan, or does it only scan one selected band at a time?
  • 90 Answers
You can't add to the preprogrammed search functions, but you can program frequencies from these bands into any locations you wish within the 100 programmable channels, where it will jump bands while scanning.
Posted on Oct 09, 2008
Midland 95 plus
Again another radio with illegal mods to go out of freq bands and FM is not authorized here by the FCC in the USA. I won't provide solutions to anyone with these radipo types. You want more bands, freq.s, power? Go Ham..
May 14, 2014 | Radio Communications
How do I re-program my Yaesu FTC-1143 to the Ameatur 70m Band
Hi Rick,
If I'm not Wrong, You have the UHF Model radio, and therefore can't program VHF frequencies as it's the wrong band. If I am wrong, then you have a dual band radio, which should be pre-programmed with all the correct frequencies for both 2m & 70cm bands.
I hope this answers your query.
Cheers,
Peter
Nov 08, 2012 | Radio Communications
I would like to pre program a new fax #. add it
1. Press function 64 set to print out a directory.
2. Press function 72
Choose 1 touch
set
press the next available number with the small yellow numbers such as 02
enter fax number
set
enter name
set
Continue or press STOP
Mar 27, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Bands covered by Furuno FS-1502
It doesn't appear to cover the ham bands, only maritime. This radio is also not type approved for operation on ham bands either.
You can find the freq. range in the manual at the link below:
http://www.furunousa.com/Furuno/Doc/0/AHHEA1GA2ITKN04R23GBMOTKF1/FS1502%20Operator%5C%27s%20Manual%20Vu.pdf
Nice Radio though.
Sep 12, 2009 | Furuno FS1503 (199 Channels) 2-Way Radio
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
Cant program frequencies into my uniden bc72xlt scanner
Just to verify you are trying to program frequencies the scanner is able to receive.
This unit is limited to the following freq range.
25.0-27.995
28.0-29.695
29.7-49.995
50.0-54.0 5
108.0-136.9875
137.0-143.995
144.0-147.995
148.0-174.0 5
406.0-419.99375
420.0-449.99375
450.0-469.99375
470.0-512.0 6.25
If the frequencies your are trying to enter or outside these bands you will get a error.
Next Direct Entry Mode Programming
Press Func. + PGM
Press E to enter ch in current location
To change location pres func + Up ^ or down key to choose location then press E
Enter your freq then press E
Hope this helps.
Jul 21, 2009 | Uniden BC72XLT Handheld Scanner
BC72XLT program/scanning problems
1. If you mean on "bank" of channels, then you have locked out the others. To unlock them, place the scanner in "scan" mode & press each button that corresponds to each locked out bank until all are "on", as indicated near the top of the LCD. If you can't scan "bands", meaning all frequencies between 25-54, 118-174 & 406-512 Mhz, you may be stuck in the "capture" mode. Let me know if this is the case (not likely) & I'll coach you through it.
2. No.
3. No.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
New Zealand
Do you have a list of correct freq's for your area?
Make sure you have the scanner set on the correct mode (am/fm/ct/dc) for the freq's you have programmed. Each area of the country have their own individual freq. so their not stepping on each others transmission.
Jan 12, 2008 | Radio Shack Pro-84 Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
175 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
