You have told us the operating system, but not what type of computer you have. For example if the video from the device is good you could, if the computer has an audio in socket, use that to connect the device. Many VCR's etc have audio out so just use that as a direct connection, then it doesn't matter if the capture device sound settings don't match your computer's. The main thing is the video feed is good.
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Ok check you have enough RAM the more the better, Check how much hard drive space is left, on your 60GB drive, sometimes if there isn't a large amount of space ..like 10 - 15GB you can have problems. Actually I would also suggest you try another program to record to your PC. try Dscaler this is simply the best there is.
http://deinterlace.sourceforge.net/ Even though it says for TV, it is the BEST recording program out there and works with most input devices.
I am using the same system... I have figured out how to get video but i cannot get audio... after i have recorded a video i am able to hear what audio i should have been able to while recording but only after i play it back.
The way to get video is to open the capture tab then click capture video then click options then click video and audio capture property settings. you then need to change your video input source to composite and your tv system to NTSC or PAL if ur in like UK or something.
I had the same problem and found that if I went into the options and chnged the format from NTSC to PAL and then back to NTSC it would bring in my camera. Thanks to snrobby for the hint on the options idea.
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer. 2. Placed the installation CD (that came with the product) back in the CD drive. 3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:- 5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
