I just replaced my motor in my 1999 kawasaki ninja EX250 (ie) bad motor . I replaced it with a rebuilt motor with 1500 miles on it that motor came out of a 98 NINJA EX250 but now when I try to start it the motor turns over but no start and ever once in awhile the bike backfires what is the problem I replaced the starter and the sparkplugs and put fresh oil in the motor PLEASE HELP THANKS JAY
SOURCE: on a 2000 kawasaki ninja 500r (ex500d7) how do I
You will need a maintenance manual for this full proceedure or visit the site www.ex-500.com and read articles on this. It is too complicated to explain without pictures and in this small space. Basically it involves removing the cam chain tensioner, setting the camshafts and crankshaft on the appropriate marks. Reset the cam chain tensioner and reinstall.
SOURCE: what is the torque on the 12 nuts on the bottom
they actually put those in nM. go with 5lbs of pressure and what year is your bike. i know a easy mod that will change ur US ECU to the European ECO meaning 9 more hp
SOURCE: there is a 2001 kawasaki ninja 250r and its engine
Yes, the engines and frames are the same.
SOURCE: how do I compress valve springs on a 1999 kawasaki
Go to this web site, it has almost everything you will ever need to know about your EX250. The people there are very helpful and very knowledgable.
http://forums.ninja250.org/
SOURCE: 99 kawasaki ninja EX250 motor swap for a 98 NINJA EX250 MOTOR
I would try charging the battery. Take it off and put it on a slow trickle charge overnight. Batteries usually only last 3-4 years if it is an acid battery.
