Question about LG Prada KE850 Cellular Phone
My touch screen dosent work.
I tryed to take my lg prada phone apart to put a new screen on, took all the screws out and took back off then front when i found out that i didnt know how to do it i put it back together, now my screen dosent work and i dont know why ??
  • Crystal
    Crystal Oct 06, 2008
    I have damaged my phone & want to buy new housing / take it apart and put it back together - but I'm afraid this will happen! If anyone has successfully taken apart and reassembled this phone PLS let me know. I'm just afraid to take it apart..
Http://www.formymobile.co.uk/Dismantle/ke850disassembly.htm
Found this.
It has some detail that may help you.
There is a link to buy more detailed instructions on ebay - but i havn't tried them
hope this helps
If you find more detail (or buy the link) i would like to see it. I have a new housing for my daughters prada but got a bit worried when taking the front off so left it
Joe
Posted on Nov 08, 2008
How do you get a touch screen to work the phone is working but the touch screen isnt
LG has released a line of cellular phones that come equipped with a sleek touch-screen LCD display. Since these screens are high-tech and sensitive, they can be prone to damage or scratches. If the touch screen on your LG is damaged, and you don't have the money to take the device to a service technician, you can open up the phone and replace the touch screen yourself.
1. Turn off your LG and slide the back battery door down and off of the device. Lift the battery out of its compartment and use your Phillips screwdriver to remove the four screws located on each corner of the compartment.
2. Use your fingers to remove the back panel from the phone. The green motherboard will be revealed underneath.
3. Unplug the four ribbon cables that connect at the middle of the motherboard. Unplug the antenna cable in the top-right corner of the board. Lift the motherboard out of the phone housing and set it aside.
4. Use your Phillips screwdriver to remove the two screws located at the top of the phone housing, then separate the back frame from the front housing of the phone.
5. Lift the damaged LCD screen out of the phone housing. Replace it with a brand-new LCD screen (available from your LG retailer or online) and reassemble your phone in the reverse order you took it apart.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | LG Vu CU920 Cellular Phone
My LG Prada KE850 seems to be frozen, will not go to main screen!
Dec 15, 2009 | LG Prada KE850 Cellular Phone
Lg prada ke850 black screen
My Phone has done that a couple of times before. It would slowly start turning off more & more often then it wouldn't turn on with the same problem as you.
Turns out it was the battery as it was a couple of Months old & was out of warranty.
Aug 15, 2009 | LG Prada KE850 Cellular Phone
LG VU GOT WeT!!!!!!
Ok. Heres what happened to me:
I forget my LG Vu (CU920) was in my pocket and I jumped in the pool. I was in the pool for about 10 minutes before I realized. It was full of water. I took the battery out as soon as I realized it. HERES HOW I FIXED IT!!!!!!!!!
Step 1- I took it home, removed the screws on the back panel, and removed it. Now the entire back casing was off.
Step 2- I put the phone and battery (separate) in a bowl of uncooked rice. Sounds crazy but this absorbs all of the water. I left it in there for 2 days.
Step 3- After 2 days, I put the battery back in and everything turned on. Only problem was there was a big bubble in my LCD screen. I then took the phone apart further by popping of the front casing of the phone. I then try to get underneath the LCD to air it out, but I accidentally broke the LCD screen (inside the phone...not plastic outer screen).
Step 4- I went online and purchased a new LCD screen for around $40 from a cel phone parts website. I got it and installed it which was not too hard. You just have to remove all the visible screws (i believe there are 6) from the back side. Then pop off the front cover and the rest is pretty obvious.
Step 5- Put it all back together and it all worked again!
Step 6- My battery soon died after of all this...Im guessing from the water damage. I bought a new one online for around 20 bucks. Now the phone is good as new.
All in all spent 60 bucks and revived the Vu from water damage!!!!!!!!!
Jun 28, 2009 | LG Vu CU920 Cellular Phone
The touch screen on my lg prada ke850 wont work.
please go to your service center and reset your phone by totaly dismantlement it,one of the wire is deattached to it so it is not working
May 19, 2009 | LG Prada KE850 Cellular Phone
I have an lg prada ke850 touch screen phone and I was trying to set in a security code but instead I just locked my phone. Can you please help? I don't know how to unlock it!!!!!
This is a small tutorial on how to hard reset the lg prada on request for forgotten security code. Turn the prada on without a simcard and wait for the insert sim screen. On the touch screen hit call, after enter this code 2945#*#. and you will see a menu pop up headed "Engineering menu". scroll down to factory reset hit that and wait for it to reboot.
Best Regards
May 14, 2009 | LG Prada KE850
LCD screen broken, have parts, want to know how to change them
THIS is what everybody else leaves out!!! first open ur phone and there are four sticker pads in the corner, use something with a sharp point to remove. Then use a phillips screw driver to remove the screws. the top with now come off, next there is a ribbon cable from the touch screen to the screen itself, On the connector there is a small plastic lever u will need to flip up in order to release the cable. Use a solder iron to remove the wires and it helps to write down on a paper where they go! do NOT LEAVE THE IRON ON THE WIRES TOO LONG!!!!! just enough to melt the solder and remove the wire, same for putting the new ones on! Next carefully remove the screen, it is held in place by sticky tape, be careful not to crack the cover, just be patience and do it slow! and put the new screen in in reverse order!!!! hope this helps!
Tallcool1
May 04, 2009 | LG VOYAGER VX10000 Cellular Phone
Everything works but the touch screen.
caring for the touch screen includes touching the screen with clean and DRY hands., if your phone fell in the water, it will likely damage the touch screen.. contact your nearest LG repair center.. i hope your phone will soon be fine..
May 01, 2009 | LG Vu Cellular Phone
LG PRADA WONT TURN ON
I'm having the exact problem. I've took the battery, SD card, and SIMS card out and put it back in many times but nothing works. It freezes at the PRADA logo! Help!
Dec 17, 2007 | LG Prada KE850 Cellular Phone
LG PRADA PHONE TOUCHSCREEN NOT RESPONDING
Ok after a bit of research I understand that the Lg Prada phone uses a Capacitive touchscreen technology. Wiki this and you will find that the plastic strip attached to the underneath of the front cover of the phone (with its circuit ribbon that connects to the main circuit board of the phone) has a sticky substance holding it air tight to the underside of the front cover. This sticky substance is Indium Tin Oxide (ITO) and conducts a continuous electrical current accross to the sensor. So if you have bought a new cover from ebay etc like I have and replaced the new cover with the old scratched one, you need to get yourself some ITO sputtered onto the screen to make its capacitive touchscreen technology work again.... hope this is a more technical answer than some of the idiots that post unhelpful solutions to questions(solution 1!).
Nov 08, 2007 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
73 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
