Question about Toshiba 65H81 65" Rear Projection Television
Still have the same issue with NO on screen display please help thanks
Hey guys.. i have a Toshiba model 65h81 and had a convergence issue so i replaced the stk392-110 with the stk392-150 and now i have perfect convergence however Now i have a completey different issue where i have no OSD, no menu volume etc. please help. thanks :)
Checked all Cables and rechecked again. everything is plugged in :( I will look later on tonight at the Pico Fuses.. Im thinking it might have somthing to do with the Eprom? thanks again for the help / advice.
2 Suggested Answers
  • 4234 Answers
SOURCE: Toshiba 65h81
Somewhere along the line you may have missed a cable connection. Recheck to be sure that all of the wires are reconnected. Also, check the +5V line. In the area of the convergence Ics there should be a number of pico fuses. One of those may have opened up.
Keep us posted.
Dan
Posted on Jun 09, 2008
My Toshiba 65H81 65" rear projection TV's picture
You do not have individual lamps in that model. You have 3 individual picture tubes of which I don't believe they are bad. They have fluid in a reservoir that becomes cloudy after time and needs to be replaced, however this is something you cannot do yourself. I recommend you call a qualified technician to take care of it for you.
Nov 26, 2010 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 Displays static, however menu screens fine
Well in this case you may have an issue with your Video Board, if the static showed on the menu, then the issue would have been with your DMD Board, but not in this case.
Jul 27, 2009 | Toshiba Televison & Video
Convergence Issue- Toshiba 65H81
Guys, I 've replaced my STK's and and it was a 2 and a half hour challenge job for me, in the hope I solve the dreaded red light blinking issue. I have soldered both STK's nice and neat and everything looks in order. One of the problems you might face, is your soldering gun. There are 4 heavy duty pins that keeps each STK in place, and you need a powerful gun to take care of those. The rest of the pins are very small, and you need a different setup for your soldering gun. You also need a suction pen to be able to to take all those pins out.
But it's not a heavy headache, it's just a light one:)
Also the thing is to remember each wire assembly you disconnect and put it back. It takes patience, and you don't wanna destroy them :( For some , that by itself could be a challenge. The Board containing the two STK's is connected to the power board with three neat assemblies....you pry those up from the top suction, and away from the power board.
BUT, as I recall, most of the challenge has to clear that board loose.
I hope this helps.
Nic
Aug 19, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65h81
Keep us posted.
Dan
Jun 09, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65h81 convergence problem
Give this a shot.. in the front of the tv when the access panel is off to where you can see the tubes. look off to the right and you will see a set of 6 small black knobs. The top knobs are for color the bottom knobs are BLUR.. turn those and see if they will help. ~Matt~
Apr 20, 2008 | Toshiba 65H81 65" Rear Projection...
Power led blinking
possible.. convergence ic can cause this problem if they become shorted
Apr 16, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 Step By Step
Could I get a copy of that manual please? Sometimes my remote works / and sometimes it doesn't. I use other remotes which are programmed for the TV, but it's the receiver eye on the TV which is intermittent. Does anyone know of a fix??
Mar 25, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Horizontal Curvature with convergence problem
DA, convergence circuit has failed, the IC`s and possibly a couple of support resistors need to be replaced, your right about it being a good set, 6 years is about average for convergence IC`s, call your local shops for a few estimates and get it fixed, it will run for a lot longer than 6 years, hope this is the advice your looking for, e-mail me if you have more questions, BMW Rider
Dec 10, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 65" Rear Projection Television Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
