Question about Kenmore Kitchen Ranges
Old range oven door seal is gone, can this part be repalced
  • 39 Answers
Hi gouda1
yes it can be replaced. some of them are a bit more invovled in doing so but some of them just pop right out and in depends on the make.
brent
Posted on Sep 29, 2008
How do I replace an oven door seal?
Piece of cake. Use pliers and pull on the small metal clips that hold the old seal on the door. Now simply press the clips on the new door seal into the same holes. The ends of the door seal should point to the floor when the door is closed.
Sep 28, 2015 | Kitchen Ranges
I have a Kenmore Elite Double Oven Range Model 790.9750. It's just 2 years old. It has been burning food only in the middle of the left side of the upper oven. Nothing cooks correctly because that
Check your door seal by doing a paper-pull test. If the paper pulls out easily on one side and not the other, then you found your problem. You might be able to "tweak" the door, but be careful - if you twist the door too much, you could break the glass. The other (and safer) solution is to replace the door seal. Another thing that could cause uneaven heating would be an element that has a "hot spot", but this is rare. Finally, if the insulation of the oven cavity was done improperly at the factory, that could also cuase uneven heating, but this is even rarer than an element with a hot spot. In all my 9 years of servicing ranges, I only encounter this cause 1 time. Ussually it's a damaged or compressed door seal.
Dec 23, 2014 | Kenmore Kitchen Ranges
HGS7152UC bosch oven door won't seal
Oven doors are designed to have some movement in and out to accommodate sealing against the gasket. If you're not getting a good seal check the condition of the gasket. If it's hard and inflexible you'll need to replace it.
About 5-6 years of normal use can make these hard and inflexible.
I just looked and Bosch calls this the 'Door Seal' pn 1052639
Jul 30, 2012 | Bosch HGS442UC Gas Kitchen Range
We have a Lofra dual fuel cooker 5 years old which needs a new rubber door seal on the gas oven but cannot find anywhere to obtain this part. Can you help? Pip Bedford
Hi I also had difficulty in obtaining a Lofra oven door seal but after searching and searching the internet I obtained an email address and now the problem has been solved. I received my oven door seal from the Italian Lofra company direct this morning. I dealt with a lady named Donatella and I found her very helpful. She can be contacted on donatella.talpo@lofra.it just give her the make of your cooker and she will let you know if she has one mine cost around £14. Good luck Suzie :)
May 03, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Tappan oven door seal replacement
You will have to google the parts may be very hard to find but you never know what comes up .
Mar 16, 2017 | Tappan TEF242 Electric Kitchen Range
Door seal small oven needs replaceing
many thanks, sorted. ordered at local supplier. regrards tb.
Dec 08, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
OVEN USED WITH BROKEN DOOR SEAL, OVEN HEAT HAS GONE INTO OVEN BODY AND MELTED SOME WIRING, STOPPED WORKING NOW. Have bought and fitted a new door seal, what do I do next, can I buy individual wiring parts...
hello sir/mam
good you have changed the door seal but you cant do the wiring because if the wires are fully burnt it is difficult to notyfy which wire is connected to which part of the oven so please call the engineer he will do it.
Oct 04, 2009 | Smeg SUK61MFX Gas Kitchen Range
Leaking Microwave door seal (between grated and back of door)
I think that you can get the plastic wet, ie sponge, or lick.
Jun 26, 2009 | Microwave Ovens
The oven door won't close properly, it just hangs slackly about 2 cm from the seal. it's a smeg wall oven.
the clips on these oven are canyilver type they can move out of position if opened abruptly .to refit correctly lift door upwards while pushing the bottom of the door inwards.you should feeel a strong resistance from the door springs.there should be a notch n the bottom of the hinge this should slot over the oven frame.if this does not solve the problem then the springs have probably gone on the hinges and will need to replace both hinge assemblies
Jul 11, 2008 | Smeg Kitchen Ranges
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
