Question about HP Office Equipment & Supplies
Etb split on hp 2600n laser printer - HP Office Equipment & Supplies
  • 23 Answers
New ETB is part number RM1-1885, costs about $120 USD, and you will likely have to replace it as they can't be repaired.
Posted on Nov 19, 2009
Can you clean the ETB on the hp 2600n laser printer
yes you can clean it..you can use 40% solution alcohol
May 27, 2012 | HP Color LaserJet 2600n Printer
Error 59.9 after cleaning a HP 2600n
59 errors have something to do with the ETB(electronics transfer belt).
Try reseating the belt, see if that doesn't fix your problem.
When was the last time that the ETB was replaced?
Oct 17, 2011 | HP Color LaserJet 2600n Printer
How to install etb
Dear George
As with my experience the ETB lasts for a long time. But still if you want i will instruct you but right now i do not have pictures, but i will try to post it later for your reference.
Follow these steps
1. Remove top cover
2. Remove the left side cover and you can see the connection of ETB motor and sensor wires Usually Purple color with white connector on bottom.
3. remove the connection and carefully unlock the ETB from the holders.
4. replace the one you have in the same fashion as you removed.
DO RATE MY SOLUTION
Jun 27, 2011 | HP Color LaserJet 2600n Printer
Cant get the hinge installed so that the toners open and close as you open and close the door.... HELP!!
I got a feeling that the ETB isn't seated correctly.
The ETB is that big mylar belt that lowers with the front door.
Pull the ETB out and check that both black plastic sockets are in the down position.
Now reinsert the ETB making sure that it sits in those black sockets, one on either side.
Mar 15, 2011 | HP Color LaserJet 2600n Printer
Can't remove toner cartru]idges after replacing ETB
The ETB isn't seated correctly.
Remove it and make sure that the two black plastic connectors at the printer bottom are both in the down position before you slide the ETB in.
Close and open the front cover and you should be able to watch the toner cartridges open and close.
Feb 24, 2011 | HP Color LaserJet 2600n Printer
What do I do to fix repetitive image defect issues that appear to be ETB rollers?
Swap out the ETB.
You never said what the defect is.
All three of the defects for the ETB will require you to replace it.
Dec 22, 2010 | HP Color LaserJet 2600n Printer
How to exchange the ETB unit (belt) on a HP Colorlaserjet 2600n?
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here...
ETB removal and replacement
Use the following procedure to remove the ETB (RM1–1881–000CN).
1. Remove or slightly pull out Tray 2 (RM1–1916–000CN).
2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
assembly.
3. Open the front door.
4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers
outward to remove.
NOTE : To make the removal of the right cover assembly easier, release the tab on the
inside of the cover.
5. Remove the left cover.
6. Squeeze the white link lever on the left side.
7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
8. Close the ETB.
9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by
carefully snapping it out of place.
10. Remove one (1) grounding screw from the ETB harness.
11. Pull out the white wire holder by pushing it up.
12. Pull out the ETB connector.
13. Remove one (1) screw from each hinge cam on both sides.
14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge
cam (RC1–5311–000CN).
15. Remove the ETB.
Use the following procedure to replace the ETB.
1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left
side.
2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover
and lower edge of the face-down cover with their respective slots.
May 23, 2010 | HP Color LaserJet 2600n Printer
HP 2600n gray background darkness throughout paper
Ehh, after futher reading it seems, as long as the EBT is not physically damadged, it is fine. So it all points back to the fuser. Ebay for $75 genuine HP.
But for others, just to rule out anything simple, disconnect from computer, and reset to factory defaults. Print Demo page. If still looks ugly, nothing to loose, run the service menu cleaning option, basicly heats the fuser very hot and passes a paper very slowly to catch any excess toner. I have never seen this cleaning option help but you never know. And if your print still looks like ****, you can save your beloved slow printing laser jet, replace the fuser.
Awsome instructions...
http://h20181.www2.hp.com/plmcontent/NACSC/SML/results.htm?SID=446153&MEID=B67763C2-AD42-45FD-B0E6-7D5998FCE86D
Nov 01, 2008 | HP Color LaserJet 2600n Printer
Paper jam
The paper jams are in the fuser area. Which is very hot. The following is a link to change the fuser. It may be that you can get to the jam by removing the top cover.
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Jul 01, 2008 | HP Color LaserJet 2600n Printer
ETB ASSEMBLY
Probably www.laserpros.com/pdf/HP 2600-2605 fuser-etb.pdf will help...
Oct 22, 2007 | HP Color LaserJet 2600n Printer
136 people viewed this question
Ben Johnson
