Question about Uniden BC72XLT Handheld Scanner
BC72XLT program/scanning problems
1. When on scan only scans one band, how can I get it to scan thru all bands?
2. Can new freqs be added to pre-labeled banks, ie fire, pol, etc?
3. Is there a more user friendly/complete operation manual available than what comes with scanner?
  • Anonymous Dec 15, 2008
    i think i am stuck in capture mode, and i have no clue how to enter a code considering they are 7 digits and i can only enter 6 into my scanner
I cant scan the police band 150-174 and i dont think im on capture mode .. why does it skip those frequency
Posted on Oct 26, 2008
  • 90 Answers
1. If you mean on "bank" of channels, then you have locked out the others. To unlock them, place the scanner in "scan" mode & press each button that corresponds to each locked out bank until all are "on", as indicated near the top of the LCD. If you can't scan "bands", meaning all frequencies between 25-54, 118-174 & 406-512 Mhz, you may be stuck in the "capture" mode. Let me know if this is the case (not likely) & I'll coach you through it.
2. No.
3. No.
Posted on Oct 09, 2008
Just bought a Uniden BC72XLT. and can't figure out how to just scan the preset aircraft freq.Help Barry
hit your function button and then you number 6 button you service button and toggle thru your number 6 button till you see your aircraft..and it will start scanning aircraft,,I have this scanner it hard to operate.....Barry you can email me at randymarr570@msn.com
Jul 04, 2011 | Uniden BC72XLT Handheld Scanner
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Cant program frequencies into my uniden bc72xlt scanner
Just to verify you are trying to program frequencies the scanner is able to receive.
This unit is limited to the following freq range.
25.0-27.995
28.0-29.695
29.7-49.995
50.0-54.0 5
108.0-136.9875
137.0-143.995
144.0-147.995
148.0-174.0 5
406.0-419.99375
420.0-449.99375
450.0-469.99375
470.0-512.0 6.25
If the frequencies your are trying to enter or outside these bands you will get a error.
Next Direct Entry Mode Programming
Press Func. + PGM
Press E to enter ch in current location
To change location pres func + Up ^ or down key to choose location then press E
Enter your freq then press E
Hope this helps.
Jul 21, 2009 | Uniden BC72XLT Handheld Scanner
Can bands be added to a scanner?
If you look at the specifications of your scanner, you'll see what freq ranges you can scan. without a rewire, you're not going to be able to scan anything out of those specs.
Jul 20, 2009 | Radio Shack Pro-96 Scanner
Need help on programing my 20 channel 10 band scanning radio
Here's a link to get the Uniden owner's manual... Look for the grey box in the upper right corner.. this will get you up and running ... You may also want to do a google.com search for " radio frequencies" and " your state here".. that will help you find the local radio freq's.
Here' s the link to the manual
May 30, 2009 | Uniden BC248CLT Base Scanner
Getting started with the ICOM IC_R5
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Jan 31, 2009 | Icom IC-R5 Handheld Scanner
Our scanner is a uniden BC72XLT and when it says bank the 1 is flashing and the 2,6,9 &10 are missing how can I fix that we had a friend program it when we got it and he has moved now can you help?
while your scanner is scanning just press the numbers of the banks that are not shown,(3,4,5,7,and 8) and then it should scan those banks as well.Also if you want to turn a band off just press it while it is scanning.
Dec 20, 2008 | Uniden BC72XLT Handheld Scanner
BC72XLT
You can't add to the preprogrammed search functions, but you can program frequencies from these bands into any locations you wish within the 100 programmable channels, where it will jump bands while scanning.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
Programming the BC244CLT
Hi, If I'm reading correctly, that scanner is listed as a 30 channel scanner only. You can pick freq's from 10 different bands. Here's just some of the features listed, hope this answered your question.
Mechanic
FEATURES:
  • Clock/Alarm - Large backlit LCD displays time and features "any button" snooze.
  • 30 Channels - You can program each of these memory channels to store one frequency.
  • 10 Bands - Including all public service bands, 4 "HAM" bands, federal and military land mobile bands.
  • Weather Scan - Automatically scans all national weather service frequencies.
Jan 17, 2008 | Uniden BC244CLT Base Scanner
Uniden BC72XLT Handheld Scanner Logo
268 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
