CANON ir2000 Error reads: Check Printer Cover There aren't any jammed sheets. We have tried restarting. There doesn't seem to be anything amiss, and yet we still get this message.
  • suhail aabed Sep 29, 2008
  • suhail aabed Oct 02, 2008
    thank you sir
    I will try this Solution
  • 1,326 Answers
All of the doors a closed right? I had the same problem with a IR-2000. It has to do with the cover on the left side of the copier. The door that has the drum in it. Make sure the drum is installed correctly. There is a small switch on the back of the copier that gets actcuated by the rear or left arm that is attached to the door. I fixed it by taking that door out and look at the end of the shaft/white arm and look for a worn out area toward the end and if so wrap some tape around that end to reform it and reinstall and that should do it for you. If not you may have a bad switch. It had me going for awhile, but I found it...
Posted on Oct 02, 2008
Testimonial: "thank you my freind "
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
This error indicates a paper jam. Something is restricting the paper path. Check the paper path from the Automatic Sheet Feeder (ASF) side, raise the cover and visually check the paper path. Try running a thicker sheet of paper through the printer (card stock will work) to see if you can dislodge the restriction.
Let me know if this clears the problem. If not we can try something else. Thanks.
Feb 27, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp470 keeps telling me there is a paper jam
Hello my friend,first thing we are going to check is if its a jam inside from a foreign object.So
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder.
  3. Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer.
  4. Close the scanning unit (printer cover).
  5. Power the printer on and confirm that the printer operates normally.
But in this procedure be very careful and don't push hard anything!
Jan 31, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
MP 160 flashing error E then 3. doesn;t respond to anything I try to reset it
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
mbhd13
Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
System error E000 in conon ir2000
Sir,
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Thanks
Good Luck
Apr 28, 2009 | Canon imageRUNNER 2000 Copier
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Error reads: Check Printer CoverThere aren't any jammed sheets. We have tried restarting. There doesn't seem to be anything amiss, and yet we still get this message.
check paper path ad the sensors, sometime i find a small piece of paper jamm the sensors, and the sensors thik is a problem, if the sensors are clean, then a sensor is busted,
Let me know that fix ur problem
Nov 26, 2007 | Canon imageRUNNER 2000 Copier
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
708 people viewed this question
jasbo
jasbo
