Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL
http://live.vodafone.com - GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address
http://pxt.vodafone.net.nz/pxtsend - Connection mode Connection orientated / permanent / continuous connection
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
GPRS COULD'NT BE ESTABLISHED MAKE SURE MAKE SURE YOU HAVE SUBSCRIBED TO THE DATA OPTION...WHAT IS THIS...I CANT CONNECT TO THE INTERNET COZ OF THIS PROBLEM...HELP ME PLS THANKS...:)
