Question about Siemens Computers & Internet
Help speedstream modem
The Modem Access code listed on the bottom has been reset by someone other than me, and it opened me up to malicious attacks. How do I set the Modem Access Code?
  • ssashton Sep 29, 2008
    It's a Effiecient Networks Speedstream 5100b
    Scholar:
  • 158 Answers
To setup the 5100b to connect to the internet?
1. In your internet explorer type in »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. At the login screen type in your  member ID and password.if you don remember your  member id and passwrod cal your broad band help desk
4. Click Connect.
5. If everything is successful you will get a screen that says, "You Are Connected." and your Internet light will go solid green. If you username or password is invalid you will get a screen stating such. If there are other problems you will get a screen stating, "The DSL connection is down."
try this and let me know
Posted on Oct 01, 2008
Am trying to find out if can use a router with speedstream 5100 Part # 060-E142-A02(modem access code 2038304758?
Yes you can. Connect the ethernet cable (circled in the image below) from your speedstream modem to the Lan port on your router. Hope this helps. 1c801d4.gif
Jun 24, 2010 | Efficient Networks SpeedStream 5100 Modem
"Lost" modem access code
This site may work for You:
http://www.softwaredriverdownload.com/download_siemens_speedstream_41004200_dsl_modem_manual.html
looks like a manual install of the driver packet. but it's FREE! Good Luck
Feb 19, 2009 | Computers & Internet
Cannont Access Modem
1. click START-settings-Controll Panel- Network Connections
2. right click on your LOCAL AREA CONNECTION and select PROPERTIES from the menu.
3.when properties opens, select TCP/IP by highliting it, then click on the properties .
4.once the new window opens titled "internet protocol (tcp/ip) Properties you will need to check the boxs that say "Obtain an IP adress automatically" and "Obtain DNS server automatically"
5. Click on OK
6.reboot
Hope this helps, post if you need further assistance.
Oct 05, 2008 | Efficient Networks SpeedStream 5100 Modem
How to bridge
Why are you doing this?
I would not recommend doing so unless you know what you are doing.
That being said the instructions are on the back of the modem on how to gain access.
Directly connect modem to a computer without a router inbetween. The IP of the modem should be 192.168.0.1 or 192.168.1.1.
After that you will need the access code on the bottom of the modem in order to change it to bridge mode.
Again please do not attempt this if you don't know what you are doing.
Aug 13, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Reconfiguration of Siemens Speedstream 4200
directl;y connect the modem to your computer without use of a modem.
Use IE and type in 192.168.0.1
Then punch in the access code located on the bottom of the modem.
Away you go.
Aug 11, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
go to dslreports.com, under forums see if there is a specific help for your telco or modem type. They are very helpful
Jun 01, 2008 | Efficient Networks SpeedStream 5100 Modem
Speedstream 4200 setup
I have just set up 4200 with dsl - you may find that you need to reset modem before you can configure. I was told that you need either a grey or yellow cable from your laptop to the modem. I use 10.0.0.138 to access modem. The 4200 I have was from a bigpond a/c - originally configured accordingly.
Regards,
Richard
Nov 12, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens Speedstream 4100 Modem manual installion
* You dont need any special drivers to install modem.
* Open up internet explorer, type 192.168.0.1 in the address bar and press enter key.
* Now you should see the configuration page of modem.
* On the left side, click on Advanced button, below that, you will see "connection configuration" option - click on it.
*** If it asks for modem access code anywhere, you can find the code underneath the modem. please type it ***
* Under this page, you have to enter the email address in username field and password, change the connection type to smart keep alive, click on save changes
* Now it may ask you for restart modem. click on restart. within 1 min, you will be connected to internet.
Take care
Sep 12, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
Computers & Internet Logo
434 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
