Carrier thermostat I have TSTATCCP2S01-B residental Carrier thermostat . I would like to use it for low temperature applications, around 0 celsius. I dont have it hooked up yet. Can I lower tepmerature on this thermostat to 0 celsius? Regards, Sead
    Scholar:
  • 121 Answers
No this t-stat is not designed for low temp
Posted on Sep 30, 2008
Need to change thermostat from Celsius to Fahrenheit
The first link is operators manual.
The second is installation and contains the procedure to set many functions including the display temperature.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2577ES.pdf
See page 15 function set 14. This sets F or C temperature
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2578ES.pdf
hope this helps?
Jun 23, 2017 | Honeywell Heating & Cooling
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
How do we change F to Celsius.
How to convert Fahrenheit to Celsius 0 degrees Fahrenheit is equal to -17.77778 degrees Celsius:
0 °F = -17.77778 °C
The temperature T in degrees Celsius (°C) is equal to the temperature T in degrees Fahrenheit (°F) minus 32, times 5/9:
T(°C) = (T(°F) - 32) × 5/9
or
T(°C) = (T(°F) - 32) / (9/5)
or
T(°C) = (T(°F) - 32) / 1.8
Example Convert 68 degrees Fahrenheit to degrees Celsius:
T(°C) = (68°F - 32) × 5/9 = 20 °C
See webpage
http://www.rapidtables.com/convert/temperature/fahrenheit-to-celsius.htm
Sep 23, 2015 | DMI / Briggs Healthcare 15-681-000 -...
Engine broke due to low temperature
The water expands up to more than 9% when it freeze below 0 degrees Celsius. Due to this phenomena, during the extreme cold weather when the ambient temperature falls below 0 degrees the cylinder blocks of the automotive engines often burst or crack badly.
This damage can be prevented by using the antifreeze coolant in the cooling system.
Jan 30, 2013 | 2001 Toyota Echo
Would I feel the cold while I'm inside the sleeping bag?
Some people feel the cold more than others, if this applies to you then remove about 5 Celsius from the lower comfort temperature. For example, a bag with a comfort rating of 0 Celsius might be better, if you are susceptible to the cold, than a bag that has a comfort rating of 5 Celsius.
Aug 02, 2012 | Camping, Backpacking & Hiking
Where is the the thermostat on a 2.0 , 2000 vw beetle ? Thank you
First time you might check the thermostat operating.
Heed of antifreeze coolant temperature!!!
The thermostat location for 2000 VW Beetle 2.0L is on back of the alternator at the bottom side of the bracket.
IMPORTANT NOTE: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Thermostat checking:
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 60 Celsius Degree you still warm up the engine until the lifter (pointer) reach 80 C deg. (second mark after 60 C deg.). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 90 C deg.
3. The thermostat opening temperature is 87 C deg.
4. If the hose is already warm the thermostat is out of order.
Thermostat location, Part number: 050 121 113 C, in german - "Kuehlregle".
Remark: 87 ... 102 Celsius deg.
Price around $35:
Important note: Always replace the thermostat seal, position 7 in the above picture.
Sep 27, 2011 | 2000 Volkswagen Beetle
I have a Carrier furnance that is about 20 years old. I don't know the model or do I have a manual. The thermostat is a programmable Noma (model THM301M). When I set the the thermostat to hold a...
I would start by installing a new thermostat because it sounds to me like it's either the thermostat or the control board and the t-stat is the less expensive of the two. I hope this helps you and thanks.
Jan 05, 2011 | Heating & Cooling
Yttertemperatur sensor
i would try the sensor wherever it is and then join the wires together and see what it reads
Jul 30, 2010 | 2006 Volvo V50
Ice cream will not freeze, but will make ice cubes.
Actually, it's not as you think. Ice cubes are made between 0-4 degree Celsius and ice creams are frozen below -3 degree Celsius. Your freezer temperature may be between 0 and -3 degree Celsius and that is causing the problem. An ideal freezer should have temperature between -3 and -30 degree Celsius.
Apr 20, 2010 | Samsung RS2578BB Side by Side Refrigerator
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
