Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Neptune water level
I have a one year old neptune washer. The water level is too low. The clothes barely get wet and they don't get clean.
    Genius:
  • 1,028 Answers
Ck drain hose level ..end should be 30-36 inches from floor also be sure hose fits loosely in standpipe ..possible water is siphoning out after fill up since these are low water use machines any drop in water level can cause problems
Posted on Sep 30, 2008
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage neptune front load washer not spinning
sp is the pump not running remove the hoses and clean out the pump the pump is in the back the dran hose goes to it
Nov 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water Sounds
Friend,
ngfam1 At your service!
This is normal for the Neptune!
I used to have a Neptune and I sold them too!!
The machine is wringing out the clothes good??
The Neptune comes new with water in ti from the test run!
All the water never gets totally discharged. This is one reason why everyone complains about the mold, musky or even stinky smell of the Neptune! Every day i have people here asking what too do about the moldy wet smell!
SERIOUS!!!!!
I do tell them to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make suer to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
That's Maytag!!!!!!!!
GOOD THING WHIRLPOOL JUST BOUGHT THEM OUT LAST YEAR!
Perhaps they will make some good changes!!
Hope this helps and makes you feel a little better as to some water sounds! HOW OLD IS THE WASHER??????
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Aug 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Water problem with stackable Maytag Neptune
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Feb 09, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
Oct 25, 2007 | Washing Machines
Clothes still wet washing on Maytag neptune
Your pump, or the hose between the pump and drum, might be clogged.  Could be spare change from unemptied pockets.
Oct 17, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
