Question about Sony KDF-E42A10 42 in. LCD Television
Sony LCD KDF-E42A10 Television
Heard loud pop and tv shut off, have no picture or sound, green on light flashes but nothing happens.
  • mpoplin Sep 30, 2008
    It continuously flashes, I counted yesterday and it was at least twenty flashes.
  • 10,594 Answers
Please count flashes on Sony KDF-E42A10 tv and let me know.
Its error signal and shows problem with particular area in your tv.
Posted on Sep 29, 2008
Heard a pop when I turned on tv and now nothing
don't leave it on and have it looked at---most likely is if it uses a lamp that may be the problem but if not it may be in the power supply.
May 20, 2012 | Sony KDF-E55A20 55 in. LCD Television
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Heard a pop and lost picture. Unplugged TV then turned back on. Green light in front of TV flashes as if it is going to coming on but doesn't and then the red "lamp" light starts to flash and...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 17, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Sony KDF-E42A10 turns on and then after a min the picture and sound will go away and the light "Power/Standby" will flash green. after a little bit the TV sound and video will come back on for a...
It is symptom of weak lamp that reaches at end of its working life, replace lamp in tv to fix the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 31, 2010 | Sony KDF-E42A10 42 in. LCD Television
In regards to my Sony KDF-E42A10 I heard a pop and the picture and sound went out. The green light just blinks and there is no picture or sound. What could be the problem?
I disagree with info given by expert.
Pop sound would be broken lamp in tv, take out lamp from tv and check it, replace it if found broken.
Usually lamp got broken at end of its working life span.
Aug 06, 2010 | Sony KDF-E42A10 42 in. LCD Television
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Dont know whats wrong
Please count green flashes and let me know.
There would be pause in flashes so count between pause.
Nov 06, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 42 in. LCD Television Logo
419 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
