Question about Ahead Software 8 Ultra Windows
Re-nero 6 buffer does not start.
Sir,
i have nero 6 burner and the buffer does not start which aborts the process ruining dvd, ocasionaly it may start and will take at least 35 min to burn one dvd.
i have advent pc with samsung dvd player and pioneer recorder, i have tried reloading the software many times and also striped dvd player to clean the lense but did not work, i have ruined dozes of discs but still stuck with the problem for many monthes.
Any suggestion will be highly appreciated.
Thanks
Shamsher.
Dear technologist
i was started burning a dvd using nero .
but unexpectedly my pc turned off .
after rebooting my pc, and i inserted dvd and try to burn.
but the software says "some files has not closed can not burn dvd"
Posted on Oct 20, 2008
Hi, there thanks for the email reply with offer of premium service, i have managed to solve this problem now and would share the experience with this forrum. Here is how it goes. I got this solution from another forrum which i tried and worked. 1. download utility-tools cleaner from Nero web and erase the old nero 6 with this cleaner, 2.then re-boot pc, 3,after this re-install Nero 6 and bingo it worked wonderfull. it takes 11 min, for Dvd and 8 min for cdr burning, which is just about normal.
My advice to my friends on this forrum is in addition to above process is to avoid buffer fluctuation is to clean the system before burning, ie use ccleaner for rubbish files then advanced windows care 2,registery cleaner, both programs are free for home use, Or similiar programes, another point to remember is to close down all unneccesary programms running in the background to have more ram to speed up burning process. I hope this would be helpfull to any of my friends on this forrum if you have similiar problem with Nero 6 burning.
Good Luck
Shamsher.
Posted on Sep 30, 2008
Hello Friends,
It seems nero still has a lock on the drive have you tried to Uninstall/Reinstall Nero.
Putting the drive in another pc will confirm if Nero has done something nasty windows wise to stop the drive working. If it repeats in another pc or if you cannot test this way it may be worth flashing the drive. Samsung has a live update program and some great FAQs on flashing here,
http://www.samsungodd.com/eng/Firmware/FAQ/Faq.asp
There are also links to correctly identify the exact model as you can manually update with the program by entering model number.
Oct 22, 2012 | Samsung SpeedPlus DVD-Writer 20x, Black ...
Sir, my lg cd/dvd burns cd all right.Recently,it has started giving trouble. Writing dvd, the burning step seems to hang up.The bar indicator stops at 1% and the dvd does not seem to be spinning at all.If...
you might have to uninstall the cd/dvd restart your computer then reinstall it
make sure that the cd/dvdrw is getting enough consistent power test all leads that are attached to the cd/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your CD/DVD or uninstall the driver then reinstall for this device
control panel administrive tools,computer management,device manager scroll down cd/dvdrw drives you might see a yellow question mark? this means the driver needs to be updated right click to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
May 14, 2011 | LG Computers & Internet
Free download for lg dvd drivers gh22np20
I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing LG drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
Best regards!
Mar 13, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
Need Nero's Rights to burn cd's and dvd's.
  1. Enter Nero Start Smart Essentials
  2. There you will find many options such as data, CD, DVD, etc.
  3. Select the activity you want to do.
  4. Nero will later guide you through the process.
Thank you sir.
Aug 29, 2009 | Ahead Software Nero 6.6 (600901) for PC
When I try to burn dvd using nero or any other dvd burner,
Sir,
Try updating nero as the early versions of Nero 6 where quite buggy. Also try to remove all junk files / temp files in your system using cleanup software(free download).
Thanks Good luck
Aug 14, 2009 | Computers & Internet
Nero express 6
Yes, ImgBurn is free. It is actually rumored to be much better than Nero software.
Will using ImgBurn over Nero fix the problem? I don't know. However it's worth a shot and would help in the debugging process.
Mar 22, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Low burn speed
I had the same problem before upgrading my RAM. Seems video burning software like nero are RAM hogs; if you do not have a large amount of RAM then it slowers the burning speed down to a crawl.[ BTW I didn't get maximum burning speeds using nero on a Windows Vista computer until I upgraded to 2 GB RAM] Hope this helps & please remember to rate my answer.
Dec 31, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Samsung combo cd writer
may be due buffer underrun... or may be u have inserted more data than the capacity of the cd... try burning less data once... if it doesnt works contact the repair person and get clean ur drive s lens
Oct 31, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Ahead Software 8 Ultra Windows Logo
110 people viewed this question
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
