Question about IBM MSI MS-6188 (49P3492) Motherboard
I need to install a network card for my IBM MS-6188
I need to install a network card for my IBM MS-6188 but when I put it, the board doesn't recognize it, is not a IBM card
  • Anonymous Mar 12, 2009
    tengo la misma tarjeta madre y necesito el manual para ver komo s konectan los pine de las memorias usb pork´no las kiere haceptar
    si me ayudan se los agradesko y si no pues ia k´chin... nimodos
    je, je, je...
    gueno espero respuestas
    yayayayayaya....
  • Massimo Ardito
    Massimo Ardito May 11, 2010
    What type of operative system are you using? Is it Windows 2000, Xp, Vista,.....
    Please indicate also the brand and type of network card.
    Problem Solver:
  • 8 Answers
Have you tried with a different network card? if no try with a different card. if it does not recognise it go to control panel and to add new hardware. follow the on screen procedure and see if it will see it.
If problem still persists, try doing a clean copy of OS
Posted on Oct 23, 2008
Just installed mobo ms-7091 m atx but find it as no video out ports how do i get a picture.i know its old but its my first attempt at building pc can i just install a graphics card.
I found the user manual here :
http://217.110.237.70/Manuals/Medion%208383XL%20mit%20MS-7091.pdf
Your motherboard provides 1 pci-express x16 slot, so you will need to install a pci-express video card.
Try to get a video card that doesn't need to be powered by the power supply. There are some out there that don't need to be powered, but .....
Most, but not all, pci-e video cards need to be plugged into your main computer power supply to work. If your power supply was designed to power a pci-e video card, it will have a 6 pin pci-e power connector to connect to a pci-e video card. If your power supply doesn't have this connector, you should replace the power supply with one with the pci-e power connector.
Sep 10, 2011 | Computers & Internet
Unable to boot from cd in MS6188
go into BIOS and set boot up options to boot to CDrom first
Sep 05, 2010 | IBM MSI MS-6188 (49P3492) Motherboard
When i starts the pc give me the massege f1 the reboot your pc
please chck if there is any other bootable device connected with the computer ie the printer,camera,usb pen drive , a cd/dvd or a floppy disc etc...
if they are connected then please try disconnecting them from the computer & then try turning it on....
please rate my suggestion...i will be glad....
Apr 25, 2009 | IBM MSI MS-6188 (49P3492) Motherboard
About detection of mouse
Try restarting your computer with your new mouse installed.
Jan 19, 2009 | IBM MSI MS-6188 (49P3492) Motherboard
USB 2 PCI card installation on IBM NetVista with MS Vista
Lucy,
USB 2.0 cards require 2 IRQs.
  • 1 IRQ supports USB 1.1
  • and the other the Enhanced (USB 2.0) controller.
Installing the USB 2.0 card in a slot that does NOT share an IRQ or shares an IRQ with onboard USB produces the best result. Consult your motherboard manual or online guide to determine which PCI slot is best for you.
You should also try disabling the on board USB support from BIOS setup.
Thanks
Iqbal
Apr 28, 2008 | IBM NetVista A40 PC Desktop
IBM Mainboard MS6188 on Net Vista IBM PC Systemes ??
Your machine is a Netvista 6280 or similar. Several models used that MSI motherboard. Go to http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4RZ2LT
IBM's latest BIOS and all other 6280 drivers are listed.
The MS6188 motherboard uses an Intel 810 chipset, you should not have any drive size problems, at least up to 30 GB, that could not be overcome by partioning the drive.
Good luck.
Feb 17, 2008 | IBM (61H2470) Motherboard
Bios on my ibm msi ms6188 is on german language , and i want to change on english
get the bios info corrrectly, go to the manufacturers site and download the upgrade bios software to flash ur current bios.
Dec 13, 2007 | IBM MSI MS-6188 (49P3492) Motherboard
Computers & Internet Logo
103 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
