Sewing Machines Logo
doris grosser Posted on Nov 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost manual janome decor excel 5018
Lost manual
Hassy
Level 3:
  • Sewing Machines Master 1,388 Answers
  • Posted on Nov 27, 2011
Hassy
Level 3:
Answers
1388
Questions
Helped
496009
Points
2943
Order a replacement User Manual for your Janome 5018 HERE...and it even comes with a bonus offer.
My Janome 5018 wont do reverse stitching when I press the lever. Dont have a manual
Did you press and hold the reverse button? If you did, then some link between the button and the feed dog is damaged. That may need to be repaired by a professional. However, the parts may not be available for this machine. I have at least one source for a service manual for the 5018: https://www.sewingpartsonline.com/service-manual-janome-5018.aspx . This particular online store has some of the more common parts for the Janome 5018.
Janome has the manual for the 5018 Decor Excel on the retired machine support page: https://www.janome.com/support/retired-machine-manuals/ . This is in the right hand column under Other Machines. The current link to the manual is https://www.janome.com/siteassets/support/manuals/retired/other-models/inst-book-5018-ennose.pdf . The Reverse button is described on page 7 (page 18 of the PDF).
I hope this helps.
Janome excel 5018 decor needle goes up and down when I'm trying to fill the bobbin
Usually, the needle bar moving means that the bobbin winder spindle (with the bobbin) wasn't moved all the way to the right. If you moved the spindle, then there may be a damaged part inside the sewing machine below the spindle. (The spindle may not be engaging the winding mechanism which stops the needle bar.) I've found the bobbin winder is still available at one parts store: https://www.sewingpartsonline.com/bobbin-winder-janome-653508015.aspx . However, there may be other damage inside the machine that could be involved.
See https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=24#manual for the pictures of moving the bobbin winding spindle.
I hope this helps.
2answers
Decor craftmaster manual needed
5018 Decor Excel · 5024 Decor Excel II · 5124 Decor Excel Pro are retired machines, all Decor machines. This is the only machine. You might try the following page's search box as it relates to the retired series. Without a model number, it will prove difficult to search for the manual at the site or elsewhere on the internet.
https://www.janome.com/en/support/retired-machine-manuals
1helpful
2answers
Now the dog feet won't move back up into position
Hello, Carole -
If you have the owner's manual for your Janome Decor Excel 5018 sewing machine, then you can find the diagram naming the parts of the sewing machine (page 2, English text) and showing part #22, the drop feed lever. This is the lever which controls the feed dog.
If that lever does not move either way, then there may be something jamming the feed dog (like lint) or it may need cleaning and oiling.
If you don't have the manual for your machine, see the image to which I refer here:
https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=8#manual
See this page from the manual to find out how to clean the feed dog:
https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=78#manual
Another possibility for the feed dog not moving is if you have your machine set to the "free-motion" or "darning" operation, which disables the feed dog.
What kind of bobbin for a janome decor excel 5018
Janome Plastic Bobbin ONLY !!
Available ..........HERE
3helpful
2answers
Instruction Manual
download the full manual at this link, copy and paste into address bar.
http://janome.com/index.cfm/Machines/Electronic/DE-PRO_5124#Machines_Specifications
1helpful
Instruction booklet
I was just checking the web for information on my machine, the Janome 5018 and ran across your post. I have an instruction book, if you are still in need of one, you may email me at:
[email protected].
joanne
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
