Whenever I turn off my monitor for, let's say, more than 3 hours, it displays what appear to be 10-15 lines running across monitor in a diagonal fashion -- what problem is this indicative of? The problem starts go away after 5 minutes. I didn't have this problem when I bought my monitor 2 years ago. Is my monitor dying? If so, how long do I have before it craps out?
I also have the slightly diagonal (almost horizontal) lines showing up on my eight-year-old Sony 21" "Multiscan G500" CRT. They're only visible on dark backgrounds, and gradually get fainter as the monitor warms up, but they're still there. The "color restoration" in the Colors panel of the onscreen display doesn't help. Of course the monitor isn't capable of displaying black any more anyway; maybe I'll try the resistor trick mentioned elsewhere. But if I did succeed in getting the picture darker, would that make the "retrace lines" problem even worse?
Solution #1
posted on May 30, 2006
Brad - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
This is a common problem with your Sony G1 chassis. What you are seeing is retrace lines. If it has not got too bad, you can correct it by running the 'Image Restoration' option which you will find in the Color menus of the On-Screen Menus. For this option to be available you must have the monitor powered on for a minimum of 30 minutes without going into power save mode.
Was this solution helpful? Show your Appreciation by rating it:
