Question about Kenmore Elite HE4 Electric Dryer
He4 gas is turning off after 5 seconds.
Gas flame starts right away but doesnt stay on Taking for ever to dry clothes
  • klanese Sep 29, 2008
    all vents have been cleaned in and out thermo looks good ???
  • 943 Answers
Hi . thanks for the question i would check the dryer venting the problem could be there remove venting from dryer to outside and clean thanks the appliance doc
Posted on Sep 29, 2008
  • john gagnon
    john gagnon Sep 29, 2008
    hi . Did you clean the lint screen in the dryer.you see if the air going out of the dryer is restricted . The flame will heat a hi limit thermostat causing the flame to keep cutting of . if that's all clean then you could have a faulty hi limit thermostat. or bad coils on the gas valve . remove the vent from dryer and try again without the vent thanks
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
I have a Neptune Gas Dryer MDG300AW and the flame goes out.
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
Jul 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Clothes won't dry, works sometime.
Either a bad flame sensor or bad coils on the gas valve assembly.
Jun 01, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes not drying properly
Consider a blocked air flow/vent problem or bad gas valve selonoids. Important to check outside vent door if present to make sure it is opening all the way. If not the dryer goes off on thermal overload. If vent is clear consider selonoids located on top of gas valve held in place with 2 philip head screws. One has a two prong electrical plug and the other has a three. Last check Lp tank for gas. Thank you
Jun 01, 2009 | Dryers
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Nov 27, 2008 | Dryers
Whirlpool ggw9250pwg
Is there an issue of goin to or from LP (propane) to Natural Gas?? The orfice and metering screw on the valve will need to be adjusted.
Jan 13, 2008 | Whirlpool GGW9250PL Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
