Question about Belling XOU592 / XOU593 Electric Double Oven
Belling fan assisted ovens
How do i install a fan assisted oven, can i wire it up with a 13amp fuse and put it in a mains socket
    President:
  • 1,462 Answers
No you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Posted on Sep 30, 2008
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
I am going to install my new mytag oven MEW7530WDS01, can you tell me the Amp. protection required for this oven? it is a 220V
If it is just a single oven then a 13amp fuse is all that is required for the oven.
If you are unsure, then check the rating plate.
If the total amperage does not exceed 3kw, then it is safe to use it with a 13amp fuse., Anymore than 3kw, then it should be hard wired, with a minimum 30 amp fuse for protection.
Feb 12, 2011 | Maytag MEW7530WDS Stainless Steel Electric...
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
My Belling oven isn't working at all- no power or
Be careful with one. Turn power off at the mains first then change the socket. I suspect the wires were loose in the socket and heated up and damaged the switch. If you have a continuity meter try checking between live in and out and neutral in and out on the socket
Oct 24, 2009 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Installing a B1641 oven
Providing it is just a single fan oven on it's own. then it will work fine from a normal 13 amp socket.
If it is a double oven, then it will have to be hard wired into a cooker control switch box, protected with a 30amp circuit trip or fuse.
Please rate my solution to your query.
Thanks.
Feb 19, 2009 | Neff B1641 Single circotherm super...
Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Nov 04, 2007 | Ovens
Belling XOU592 / XOU593 Electric Double Oven Logo
366 people viewed this question
Top Belling Ovens Experts
ashburton
Chris Hall
Chris Hall
Are you a Belling Oven Expert? Answer questions, earn points and help others
