Need instrutions for this model.
How many set of wires came with this model?
I switch TV's, now it flicker on the blue screeen, the counter count down but does not show the movie, it's loud also.
There are two red hole's for the wire, where does the color wire's goes.
  • 10,594 Answers
Please hook your dvd player and tv as follows...
Find Yellow color pin as Video Out, Red and White pins for Audio Out (right and left channels) and same goes to rear input-1 or input-2 what ever is available in your TV. watch out color of pins, same color in both units should be hooked up.
Now play dvd player and select input in tv and enjoy.
Still needs help, please mention model and brand of DVD Player and TV to guide you in better way.
Posted on Sep 29, 2008
Tip
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
on Jun 13, 2011 | Office Equipment & Supplies
My LG dishwasher counter doesn't count down
Since you didn't give the model number, I looked at a general user manual for an LG dishwasher. It suggested that if the water is cold, it would take longer to wash the dishes. That suggests to me that a cold water temperature might prevent the timer from starting till the desired temp is reached. Could that be the problem? Could it be connected to a cold water supply rather than hot? Is the hot water set too low?
Mar 10, 2014 | LG Dishwashers
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
I have a Konica 7065 I need to replace the developer in it and then I will need to reset the counter
to reset counter turn off main switch hold down 2and 5 turn on release 2 and 5 a different screen will show select 3 PM count/ cycle, set off and is done
Jun 16, 2010 | Konica Minolta Office Equipment & Supplies
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
Used to flicker, now dead
You possibly need to replace either the Main board, or the power board, they both can be purchased online, and you can either install yourself or go to a site like Onforce.com and accept bids.
Sep 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screeen flickers
water damage, dropped it too many times, faulty hardware. probably water damage though, thats what happened to mine.
Jul 13, 2009 | Nintendo DS Lite Console
Akai PT5998hdtv sets goes on clicks and goes off
Do not panic! Do not throw your TV away like I wanted to! Here is what may be the solution for most of the members who have posted their complaints here recently. I am not an expert, but I followed all blogs from various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it from www.partstore.com and since this Akai is the same model as a comparable Samsung Model, buy the Samsung comparable Convergence board for $77. It came to about $85 after shipping. Call them if you need the exact model #. The Convergence board has two black STK ICs and two colors of wires, a gray kind and a blue kind,all which have 'pins' and can easily be unplugged from the circuit board in the TV. It is basically a complete system that takes less than30minutes to install. It is a simple swap procedure, with no soldering.You only need the new board and a screwdriver! Remove the lower backboard of your TV where the cables are plugged in (do not unscrew all the screws for the screen, as it is unnecessary, and might just damage your screen if you are not careful.) It has a u-like shape and comes off easy.Detach the gray wires connecting your old board to the rest of the circuitry, and detach the blue wires connecting the old board to the circuitry. On the old board, there are connectors marked,from left,blue, green and red. Detach those from the old board, and mark the wires so that you may connect the correct the wires to the new board. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks which held the old board, and screw the lone screw to the board. Plug the gray cables from the new board to the connectors where the gray cables from the old board were,and do so for the blue cables. Connect the multicolored cables to the blue, green and red, just as was done on the old board. Reattach the cover and test the TV. Please do not replace the two STK ICs only. When I removed my old board, I realized that there was a burn mark, where the ICs were, but maybe it was a fuse.You may replace the ICs only to discover that it was another problem.Good luck, and I wish you all thebest in the repairs. I just savedabout$100 for a repairman just to showup.
Nov 27, 2008 | Akai PT5598HD 55" Rear Projection...
Hatchi 50V500A LCD rear projection tv.
IF IS CIRCULE BLUE A RAUND A IN CENTER THE PICTURE OK YOU TV IS DLP NOT LCD CHECK IS IF HAVE CIRCULE IN CENTER THE PROBLEM IS SERIUS COST THE NAME PART DAMEGED IS THE LENS MACHINE OPTICAL COST TO MUCHS NO COST EFECTIVE
Sep 24, 2007 | Philips 28PW9536 28" TV
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
