Question about Kitchen Ranges
Not heating to temp thermostat
Oven not reaching temp. Is there an adjustment on the control panel? Jenn-Air Model FCE30610W
  • 943 Answers
Hi thanks for the question the part that has failed is the oven sensor .Its located in the oven on left top in oven remove screw at sensor remove sensor from back cut power first thanks the appliance doc
Posted on Sep 29, 2008
Oven will not maintain tempature with what was programmed
You might try calling Sears, or wherever you purchased the oven. Or even an appliance repairman. It sounds like the oven temp needs to be re-calibrated, or buy a thermostat to put inside the oven and follow the temp it says.
May 31, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Hello, My Jenn Air oven overheats. When I set
The temp probe resistance should read between 1050 and 1150 ohms. If not. Replace it.It causes the overheating situation you describe.
Jul 16, 2009 | Jenn-Air Ovens
I was broiling on jenn-air convention oven on high about 30 minutes came back oven had turned itself off seem like it was overheated wouldn't allow you to do anything else
On this model there is a blower fan or cooling fan located between the cooktop and the oven. When oven temps reach @ 550 deg this fan should turn on to keep the controls cool. If it did not come on, you may have a bad fan thermostat or a bad fan. What happened is the control overheated and shut down on you.
Apr 10, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Dec 18, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Your manual should tell you how to adjust the temp. up or down.  If this doesn't work then replace the oven temp sensor.
Oct 21, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
128 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
