if you have tried to connect the controller using the usb and that didn't fix it try to rest your controller and reprogram it for your system make sure it is fully charged
do you have the program needed to get what you have on your flash drive? If you don't have a photo program or pdf program or what ever to open it, it won't work. try connecting something else that uses USB port to it and see if that works, then you will know if its a program problem or your computer. if its the computer, you can replace it.
So why won't it accept the printer? Is the printer and your operating system on the computer compatible? Did you install the printer and drivers? Are you sure the USB Port works? Have you tried a different USB Port?
Click Start/Control Panel and look for Printers. Open it and make sure you don't have more than one instance of the printer installed. If you do, then you're confusing the computer. You can also check to see if more than one of the same printer is installed by opening a word document, then click File, then Print, and when the print window opens up click the Down Arrow on the line that shows the printer name. This will show you all other installed printers.
Ever looked at the power specifications of a mobile charger?? well if
not, then have a peek... u will read that the output voltage is 5V
DC........ the computer USB also has a voltage output of 5V
DC........... any USB based electronic device needs this power to get
started.... The laptop coolers u get basically work on this power from
the USB... U'll notice that the USB ports have 4 terminals.... the
extreme outer side are the POWER terminals +ve and -ve..... the middle 2
are the BUS lines IN and OUT.... a BUS is something electric conductive
that allows the flow of 0's and 1's or rather high and low voltages to
pass(Basic IT theory).... so this 5V DC can be used for doing anything;
charging the mobile phone battery to lighting up entire rooms with
LED's, making laptop coolers, etc......... Every mobile phone which has
the USB connectivity option gets charged when plugged in... so sometimes
even if u dont have the Mobile charger dont panic, find a computer and
plug in the USB... not only micromax x225 mobile but, there are almost 80% mobiles which
charge by connecting it to pc. Only nokia phones don't get charged. it
is a good feature don't worry
solution : 1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer. 2. Reinstall driver printer (don't connect printer USB cable to computer). Wait forthe install process,untilmessage "connecta printer USB cabletocomputer". After message appear, connect printer USB cable to computer. 3. Wait process install finish and try to print.
When your MP3 is connected to the PC. Click start -> Right-click 'My Computer' -> Properties -> Device Manager and your MP3 may show up with a yellow exclamation mark next to it on this window. Right click it and select 'Update Drivers'. Click next, Tick the option 'Let me choose driver...' then choose USB Mass Storage Device and click next and it should work.
If you are trying to capture from a digital camcorder (tape), you have to use a firewire connection, USB does not work as stated in requirements.
Adding to what Walt said, firewire cables don't connect to a USB port. If you don't have a firewire cable, you need to purchase one. And if you do, don't buy a cheap one. Buy cheap, buy twice.
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this problem?
