Question about Kenmore Elite HE4 Electric Dryer
Kenmore 90 Series Electric Dryer won't start
Lights are on, but the start button no longer works. Can anyone help with a fix?
  • 943 Answers
Hi.Thanks for the question I would look to see if the belt is ok.Some dryers have a belt break switch, which is located by the motor.I would check the door switch.on the door try that thanks
Posted on Sep 29, 2008
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 30, 2011 | Kenmore Dryers
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Doesn't start
Try this link and see if this helps you diagnose your problem. Please don't hesitate to contact me if you require further assistance.
http://www.fixya.com/support/r385301-thorough_dryer_advice
I hope this helps you isolate your problem. Let me know if you need assistance in locating parts too.
May 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore 90 series
i have no solution, my dryer won't start but the buttons light up and it makes all the sounds but won't start? It's gas by the way if you have a solution pleasee-mail me back, or if you know someone who can fix it. HELP!!!!!!!!!!!! sheri
Apr 09, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
82 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
