Question about Belling Kitchen Ranges
Do you need to hard wire the belling xou59455, or can you put in in a mains socket with a 13amp fuse
    President:
  • 1,462 Answers
If this is a double oven, it needs to be connected to a proper cooker outlet and wired back to the consumer unit
Posted on Sep 30, 2008
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
Main fuse tripping
remove the cover from the heater spray with wd40, wipe dry, replace the cover and re-try
Dec 15, 2013 | Computers & Internet
Amperage required to run a 180 amp welder
If you mean the plug rating, you can run a 180amp mig welder on a 13amp plug, however above about 150 amps the fuse in the plug will blow, you then need to up grade to a 16 amp plug and wall socket, with the wall wiring going back to a fuse box with a 20amp fuse.
Jun 16, 2011 | Miller 041969 Secondary Contactor Kit
The 13amp fuse blew in the socket and when replaced the light and fan worked in the oven however no heat was produced...any help would be greatly recived the oven is a newhomes el616.
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Start" button has not been depressed due to the wiring of the switches or it can take the mains power fuse out and stay faulty.
Check for faulty door switches and/or contaminated actuators.
Alternatively, the magnetron, supply or HV diodes can fail and take the mains fuse out.
I hope that helps.
Mar 14, 2011 | Microwave Ovens
Not to sure what wire to use and if I can use a plug
You can use it a 13amp plug if it is just a single built in oven and the total wattage does not exceed 3000 watts..
Anymore than 3000 watts, then it will have to be hard wired into a seperate control unit with 6mm twin and earth cable.
Feb 19, 2011 | Belling Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Installing a B1641 oven
Providing it is just a single fan oven on it's own. then it will work fine from a normal 13 amp socket.
If it is a double oven, then it will have to be hard wired into a cooker control switch box, protected with a 30amp circuit trip or fuse.
Please rate my solution to your query.
Thanks.
Feb 19, 2009 | Neff B1641 Single circotherm super...
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Nov 04, 2007 | Ovens
Kitchen Ranges Logo
136 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
