Question about Microsoft Computers & Internet
USB drivers installed aversion of Vista in my PC which had Xp, but y usb ports do not work, what should I do?
    Novelist:
  • 186 Answers
You need to find out the make and model of your motherboard, go to the manufacturer's website and download vista device drivers for your motherboard - if they have them. If the board is pre-vista the manufacturer may not have vista drivers for it.
If you need help finding the make and model of your motherboard, go to this website - http://www.belarc.com/, download, install and run the program. It will give you all sorts of information on your system.
Posted on Sep 30, 2008
USb SXC -1080 modem of tataindicom causes problem with vista
the usb modem you are using is compatible with windows vista but for that u need to install the driver software ie sxc 1080 vista dialer 32 bits . you can download this software from the tataindicom site which is www.tataindicom.com. windows 98 and vista have different software compatibility.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
I have installed the disk "dolphin 1.5" Digital Photo Frame with key chain (photo viewer V208G2 and am unable to get the thing installed. I run Windows Vista
s.wingard,
Are you sure the Dolphin Digital Photo Frame is compatible with Windows Vista? When I searched, all I saw that was supported was XP and 2000. Once drivers are installed and they do not work, it's best to uninstall the driver (in the control panel in the system hardware configurations). Delete the driver and restart the computer with the picture fram plugged into the USB. You should be asked if you want to install the drivers. You then pick the custom location for drivers and browse to your drive with CD. You should be able to find the drivers somewhere within the disk (usually contained in it respective OS Folder e.g. WINXP). Load that particular driver.
Hope this helps,
Bill
Sep 11, 2009 | Computers & Internet
Driver for ZTE WP560BD Qualcomm USB Modem under Vista
Put the USB stick in your USB port and wait a few seconds.
When there comes a popup choose folder view.
When not open your explorer and surf to the folder of your USB drive.
look for the installation folder.
You'll see a file named setup or install..
Stay on that with your mouse pointer and click right a menu popup.
Choose properties and choose compatibility here you can choose vista SP1, vista SP2
XP SP3.
when its done run the setup this will work to install the drivers and the aplication software.
I hope this will help.
Best regard: Henk® Mµskita ©2009.
Jan 18, 2009 | Microsoft Windows Vista Ultimate Edition
Windows xp not recognising any hardware e.g.Pendrive,bluetooth
check are your usb driver is properly installed or they are enabled... I happed with me also... It took some time to locate and install the usb by windows but it can also be the cable problem... Check these things and if nothing is wrong within these then try to reinstall the windows and i am sure that this will solve your problem!
Nov 04, 2008 | Microsoft Windows XP Professional
Usb 2.0 windows 98
Go to  http://www.technical-assistance.co.uk/kb/usbmsd98.php  and read it carefully.  Download the correct version of nusb and follow the installation instuctions to the letter!  Be prepared to spend a little time identifying any software in your Add/remove list that you don't recognize - don't guess - and remove USB devices from Safe Mode, to be certain you don't miss any.
If your mobo is USB 2.0 capable, you should now have it; if it's not, at least you'll have a generic USB 1.1 facility.  You should not need to remove viewer or album software, just the USB drivers and devices, but if you're of a nervous disposition, backup your system before you start!
Aug 23, 2008 | Microsoft Windows 98 for PC
Facing ploblem while using TATA indicom USB modem in Vista Home Basic
Hi I'm Sathiya. I use Windows Vista Home Basic platform. I recently bought a TATA Indicom Plug to Surf connection. It had issues with drivers. I went to Tata indicom site and downloaded the latest driver for Vista. After installing the drivers, my connection is working fine. Make sure that you choose the right version.
Jun 27, 2008 | Microsoft Windows Vista Ultimate Edition
Driver Issues on Windows Vista Basic
As an adhoc solution you may try to download drivers for XP SP2, tell the driver installation applet to search for drivers from the folder you downloaded them to when it tells you this driver was not made for Vista tell it to install them anyway. It may not work but as this manufacturer is no longer in the modem biz vista is not supported by them at this time.
Jan 15, 2008 | Microsoft Windows Vista Ultimate Edition
How to install XP on pre loaded Vista in HP Laptop
I bought a cheap Compaq laptop that came with Vista Home Premium. The speed was horrendous! Anyway, I received the same no hard drive found error. To solve the problem, I went into the system config (BIOS) by pressing F10 on startup, and turned off SATA hard drive support (its supposed to make the hard drive run faster), I rebooted, inserted my Win XP Pro disc and viola, it detected the hard drive. I would say that the laptop runs a good 40% faster than before. Vista is a big no no when it comes to low end laptops built for word processing and internet browsing.
Aug 19, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
