Did the new DPS-336A resolve your problem? I wanted to know as I am considering ordering one since the one I have looks good and there is not any information on what actually needs to be fixed on the board.
Thanks,
Brad
Comments:
Sep 29, 2008
- Thanks for the quick response!! I have the old board out and I am ready to replace it with a new one but I just need to take the risk and order the new one. It's too bad there is not a newer board available or a replacement board available as I am some what skeptical about putting in the exact same board with a track record of failing. The other odd thing is how the current board does not show signs of obvious failure. It would be nice if they would even share with the public what part of the board is failing so we could address it specifically rather than ordering a new board. It would reduce the cost invovled for the repair that is for sure. I'll definitely keep you updated with my results.
-   I believe my power supply is also bad. I can hear a squeal from it when the unit is powered on. Symptoms are red and green dots appearing randomly around the menu items. Did either of you notice a microchip on the backside of the power supply with 2 legs cross soldered. It just didn't seem right to me. Would love to find a schematic.....
-   lord_snot
Surveillent what were the symptoms for your tv that helped you figur out power supply issue?
lord_snot do you have 8 lines or do you see any lines seen on the menu. I have lines and multicolored dots on menu picture displays with red and green all over screen and only in a/v input hd ypbr 1 or 2 ypbr do not detect input. do you get a picture in a/v mode whats it look like can you send me a picture su
surveillent.... i have the same issue as you.... thing is i never took pictures to make sure if what i would be plugging back in would be in the same place....
can u mail me those pics? tripero01@hotmail.com
i would really appreciatte it.... thanks in advance
I was going to post later this week but I have been running perfect, without any problems at all for over 6 days now! I just went in and replaced the DSP-336AP. I took digital photo's once I pulled the back off to be sure all connectors went back on and I was careful not to touch any other wiring. You will need to also pull of the power cable connector in order to pull off the power supply cover as well as it slides out and the power connect thing blocks it. I did see that although the revision of the DPS-336AP was exactly the same as the newly purchased one, the serial number of the one I purchased on eBay was a few hundred newer or higher. I was hoping that it was a new rev and hoped that Westinghouse fixed the problem. Nonetheless, all is working perfectly once again. I paid about $150 for that DPS-336AP on eBay and there were only two sellers on eBay offering this board. Good luck and please take the time to update me as well. I suspect W sold a few thousand of these TV's and you and I will be the only ones who fixed them ourselves. Anyway, good luck to you!!!!!!!
Was this helpful?
Yes
No
Popular Solutions for Westinghouse LVM-37w1 37 in.
I have the westinghouse monitor ( modeL # lvm-37w1) nad the picture keeps going nuts on the left...
(More)
I have the westinghouse monitor ( modeL # lvm-37w1) nad the picture keeps going nuts on the left side of the monitor only. anyone know what could be wrong?
lvm-37w1 . sound works but picture is completely scrambled. The screen has horizontal lines moving...
(More)
lvm-37w1 . sound works but picture is completely scrambled. The screen has horizontal lines moving up and down quickly. Used to happen here and there, but now it doesnt go away. TV worked fine all day yesterday.
