Question about LG WM-2277HW Front Load Washer
LG WM1814CW leaking water from the filter compartment on the fron
I washed a load of clothes and water is everywhere....it is leaking out of the little hole for the filter on the front....I opened and rinsed the filter even though it was not full of anything. When I put the filter back in....it does not tighten up completely and water still continues to pour out. It looks like silicone or a lubricant is on the filter parts and I need to lube or just need a whole new basket all together. There are no visible cracks or anything wrong with it.....but can't get the water to stop and even though I tighten the filter back in.....it still leaks.
  • 1 more comment
  • SKW914 Sep 29, 2008
    Ok--so I replaced the seal on the filter basket.....didn't resolve the problem......water still rushing out....may just need to replace the part all together....but am open to suggestions if anyone else has had this issue!
  • SKW914 Sep 30, 2008
    I am going out of town, but when I get back I am hoping that my brother will be able to help me look at this and will post a response then. I know it's definitely coming from the filter because when I tried to check the new seal it was pouring out of the filter--no slow trickle!!! I really appreciate the response and am hoping this does the trick!!
  • SKW914 Oct 15, 2008
    Ok--so my brother finally got over to check it out...it turned out to be the filter compartment after all. He lubed up the o-ring/seal and apparrently it needed a little male force....I guess my girlie strength wasn't enough...but at any rate he was able to put the basket back in and tighten it up and it no longer leaks!!! Figures!!! As a single mom....I am just glad to have it fixed!! I have taken the basket out before and had no problem putting it back in with no leaks. I think the old seal/o-ring had broken and I just need to lube the new one and use a little more muscle to get the basked back in place. Glad it wasn't a gasket!!!!
  • 706 Answers
Hello SKW914.. Here is a link for the service manual http://136.166.4.200/contents/Laundry/WM1814/WM1814_Service_Manual.pdf
If you look on pages 35 and up, you will see the filter trap assembly and all the surrounding hardware. If after you reinstalled the filter ( with a new gasket) and it is still leaking there.. you may need to replace the assembly itself if you are sure it is properly threaded in and not crossed. You can use vaseline on the threads and gasket. I am assuming that you verified it is truly leaking from the filter compartment and not the front door. The hinges on the front door get damaged if you use detergent and fill it to the full mark.. they don't tell you to use about 1/4 of that and if you continue to fill it up to the mark..the run off trickles down and is caustic to the hinges and then the door won't seal right.. Make sure you verify the source of that leak before replacing anything you don't need.
let me know if I can help you any further.. Good Luck
Posted on Sep 30, 2008
  • Rick Gelin
    Rick Gelin Sep 30, 2008
    If you are sure it is leaking from the filter compartment.. it may not be the filter but it very well be the compartment itself.. If you pull the washer out from the wall and remove the back bracket that holds the top cover.. then unplug the door switch .. and remove the screws holding the front panel assembly onto the chassis.. ( you may need to unscrew the filter compartment screws too) .. You should have access to see everything you need to in order to truly identify the source of the leak.. Good luck.. I'll be keeping an eye out for exactly what you find.. please post it and don't forget to rate my support for your problem.. ( when time permits and we get it all fixed up)..
    Regards
  • Rick Gelin
    Rick Gelin Oct 23, 2008
    Hello SKW914,
    I am glad that your problem got resolved and that it wasn't anything of major expense. Sometimes even the simplest things (like the gasket not sealing properly) can be quite annoying. I am just happy that you are all set now.
    Regards,
    Rick
How do I put hose back in behind lower cover cap? pulled completely out when attempting to drain hose & clean the pump filter.
Go to www.youtube.com and enter
LG WM1814CW
Into search bar on youtube.
You will see various videos on How To Fix your exact model washing machine. :) x
Nov 17, 2014 | LG WM1814CW Front Load Washer
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
LG Tromm Model # WM2075CW doesn't drain - water everywhere!
This is joyce
I hope you have not been waiting long for this answer, go to the website lg.com dowload your document on your washer put in your model # first and then it will give you all the info you need on that machine even trouble shoot it and codes. I hope this helps.
thanks,
joyce
Feb 04, 2009 | LG WM1814CW Front Load Washer
LG WM1814CW
I thank you for your support on fixing my OE error. I cleaned out my filter on the bottom left hand corner of my machine. Problem fixed. Be aware that when you unscrew your filter, you may have a lot of water draining.
Sep 21, 2008 | LG WM1814CW Front Load Washer
Whirlpool MDLslr8233eq0
my lg and others with the 1814 model, seem to have the problem also, watch the back side whenit goes into the rinse cycle , on mine @aout 7-8 minutes left. mine was blowing out suds and water through what is an air vent , i think. if lots of models hav this problem, we might be able to get lg to do something.
Mar 10, 2008 | LG WM1814CW Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
424 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
