Question about Kenmore 22422 Top Load Washer
Washer leaking from bottom
My washer started leaking from the bottom after i moved it outside with a dolly i cant tell where it is coming from
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your washer started leaking from the bottom after you moved it outside with a dolly you cant tell where it is coming from.
I had a client the other day with the same problem and it ended up that one of the water supply tubes were loose underneath.
And only needed to be tightened. Now you may have A hole or crack in the tube too!
So inspect it when you tighten it. You will need to people to check this!
check if you fell or see water from any other parts when you inspect below!
Be very careful and do not inspect the washer alone.
make sure the washer is turned off and unplugged before you atempt to do anything with your washer.
Let me know what you find!
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave a rating before you go!
Thank you,
Huuum
Posted on Sep 29, 2008
Kenmore Elite HE3 11042832200 leaking from bottom, cant figure out where from
Might be it is your pump. or pump hose. That is the area where the pump is. Remove the 3 T-20 star drive screws that hold the service panel on so that you can gain access and look for the leak is what I would do.
Mar 26, 2013 | Washing Machines
Leaking clothes washer, water run out the bottom when started & floods the floor
CHECK YOUR DOOR GASKET / BOOT THAT IS MOUNTED IN FRONT OF WASHER DRUM. THE GASKET / BOOT MAY HAVE CRACKS, HOLES OR HAS COME LOOSE SOME HOW, ALSO MIGHT WANT TO CHECK ALL HOSE CONNECTIONS INSIDE AND OUTSIDE THE WASHER
Feb 09, 2013 | Maytag Washing Machines
How do I get the outside cover of my Crosley CW6000W to replace the belt?
The belt is accessible from the bottom. Tilt the machine with a dolly [or something] and stack some 2x4's to hold it in a propped position, or lay it on it's side [get help if you can]. Good Luck.
Aug 30, 2010 | Crosley CW6000 Front Load Washer
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I prep my Kenmore Elite He5t washer for move to new house
Washers n dryers usually require some balancing after a move to the new area, and when you lift the washer on a dolly, you lift it from the rear. Assuming you've already tipped the washer slighlty to one side, checked the bottom for which side has the most metal underneath. This is best done with 2 people. Do the same with the dryer. The braces are used to help balance or to keep from tipping when the machine was packed inside a large box.
May 23, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Refigerator leaked oil after moving and storage
no if there was oil leaking out then that means the refrigerant has leaked all out. you will have to have it repaired by a service tech.
Feb 22, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Help please water leak
HERE is your service manual MAybe that will give you an idea
Jun 18, 2008 | LG WM-2277HW Front Load Washer
Maytag Neptune Leaking Water
pull the frount panael at the bottom and look there early model neptunes would leak around the door seal they made a kit to fix them but i dont know how old yours is so i cant tell you if thats it check the obvious hoses etc your drain pipe could be cloged the one your drain hose goes down in and just barley running over when the washer drains tell your husband to fill it then then switch to drain and listen to the pipe will sound like a bottle filling up when it drains or he will see it running over while it fills look under the bottom panel for leaks hope that helps
Dec 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 22422 Top Load Washer Logo
2,424 people viewed this question
Sal De
fordexpert
Robert Rankin
