Question about IBM Firmware Extended Fabric Activation (19P1680) for PC
"DC PROGRAMIN...." Error
I am Nazari.
I have a IBM 6400-009 printer.
I have a problem , when power on printer , display "DC Programing ... " in control panel LCD.
I thing damage printer Firmware.
My configuration printout printer is :
File Part Number 24H9390 Date 28-jan-1999
Reference Number 352910
IPDS Version 6.02
Base Coax/Twinex Version 2.05F
Base Line Printer+ Version 2.05F
DC V6.02 28-jan-99 #352908
ED V2.01M 10-Dec-98 #352769
BOOT/CMX V1.05F 10-Dec-98 #352746
SECURITY PAL 154143-002
Thank you very much for help to me.
Call IBM and request for the file P/N 24H9390
After you got the file email me, I'll show you how to reflash into the printer
Posted on Oct 25, 2008
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
What is a 19 error code on the Ibm printer 4224
Attachment Card Failed Power on Tests.
1. Switch Power off (O).
2. Wait 20 seconds and switch power on(I).
3. If the printer displays (19) again then call for service.
May 14, 2012 | IBM 4224 Model 101 Matrix Printer
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
To continue turn off then on
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Printer is showing a display error 57.03. How do i fix it?
it's a Power Supply Fan error,it is on the right-hand side,and below.
Reseat connections to the specified fan and DC controller.
If the error persists, replace the specified fan.
If the error persists Replace the DC controller
Use the Figure and table below to properly identify the 57.X error and the corresponding fan that is causing the error message.
Oct 30, 2009 | HP LaserJet P3005n Printer
Usually with this error the program checksum for the printer controller is corrupt or the data controller memory is corrupted.
You can try redownloading the program into the printer or it's possible it also has bad Flash Memory.
Jul 15, 2009 | Printronix Line Matrix P5005B Printer
P62 error code
The IBM 6400 printer uses internal programming software that is specific to the printer based on installed interfaces and graphics options. This software resides in flash memory and when the printer is first powered on the software is executed. During this process it initializes the various processors on the controller board, initializes the optional interface cards, and then loads the necessary operating settings into dram. If the programming software becomes corrupt it will fail during startup, giving you the DC Program not valid error or a number of other error messages. The solution to this is a reflash of the printer. Unfortunately, the flash software is proprietary to IBM and they will not distribute it to anybody. The only way to get the printer reflashed is by calling IBM and having one of their engineers reflash the printer.
Jan 28, 2009 | IBM 6400 Matrix Printer
P62 DC Pgm not valid
Our IBM 6400 came with a bunch of manuals.
Do you have manuals on yours?
If you need to purchase or download manuals, here is one place you might start to figure out what they cost & where to get what you need.
Oct 27, 2008 | IBM 6400 Matrix Printer
IBM 1352
DC Pick motor error: No Encoder feedback. Try to remove all paper from tray 1 and replace it.
It basically means there is a tray1 paper feed problem.
Oct 14, 2008 | IBM Infoprint 1352 Laser Printer
Computers & Internet Logo
252 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
