DEAD: Kenmore front load washing machine Super-Capacity 3.5
My wonderful washer died yesterday. Nothing. Nada. Rien. No lights, no sounds, no beeps....
I checked the power cord, the water supply and even unplugged it for 1 hour in hopes it would "reset".
Please help me to bring my Bessy back to life. She's got lots more laundry to do!
Thanking you in advance,
  • 750 Answers
Hello Lisa
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Your wonderful washer died yesterday. Nothing. Nada. Rien. No lights, no sounds, no beeps....
You said, you checked the power cord, the water supply and even unplugged it for 1 hour in hopes it would "reset".
When service comes out they go inside and test the start switch and or any fuses or wires that may be faulty.
You need to run a diagnostic check to see what part or parts failed and then you can determine by the age and cost of the repair what you are going to do!
You already tried the reset which was smart and well informed!
You did the right thing to try and reset it!
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave a rating before you go!
Thank you, Huuum
Posted on Sep 29, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ... > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ... > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Jun 24, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore Super Capacity front loading washer that has stopped.
You are referring to a top loader problem.
A front loader is different the following is from the youtube page that has video explaining the possible issues!
Washing machine not spinning? This video provides information on how to troubleshoot a front-load washer that won't spin and the most likely defective parts associated with this problem. These are sorted from most likely to least likely to be the issue.
Commonly replaced washer parts:
Drive belt
Door lock switch
Motor control board
Drive motor
Good Luck!
Rich Lilja
May 21, 2017 | Kenmore 46462 Front Load Washer
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
