I just received 2 memory cards for my Dell notebook and I need to install them.
    Sergeant:
  • 268 Answers
The bottom of your laptop should look something like this:
You want to unscrew the compartment that has the memory inside of it. Should have 2 small screws.....
Next you want to remove the exsisting memory by lifting up on the module and sliding it out....then insert the new memory , and push it back down, as shown in this picture:
When you reboot your system for the first time , it should stop before it boot's to tell you that the system's memory has changed.
Posted on Sep 29, 2008
When i try to install windows xp, then all files are extracting rightly but when start up is loading suddenly blue screen appers. so plz help me to solve this problem. give me suggestion.
Hi jenishrabadi, Have you tried using different source software for your windows xp installation.
There should be an error code when you receive the blue screen. post the code here, it may seem like 1) either corrupt software or 2 ) Faulty hardware. Most likely memory.
without further performing any more diagnostics (as we do not know what the actual error is) and making the assumption it is faulty hardware, if you have more then one memory cards in your notebook, try and take one memory card, then try the setup/install. if this fails .. put the memory card back in, and remove the 2nd memory card and try again.
good luck ... hope this helps ...
Oct 07, 2010 | Compaq Presario Notebook
How to use SDHC memory card on Dell inspiron. putting memory card in slot, but nothing pops up to capture the photos anymore
you need to search if the driver is instaled,if not go to dell.com and download the driver and this should resolve your problem.
Nov 24, 2009 | Dell Inspiron 1300 Notebook
Can't locate memory card slot for my cell phone's sandisk thing
This model does not have a memory card reader installed. If you need to access memory cards, you will need to obtain a PC Card for that purpose or a USB memory card reader that supports the card format you wish to use.
May 25, 2009 | Dell Latitude D505 Notebook
Viewing pictures on computer from memory card
you must install and update drivers laptop and install the built in accessories.>(http://www.dell.com)>good luck
Jan 20, 2009 | Dell Inspiron E1505 Notebook
Update BIOS for memory upgrade
You cannot change the memory settings in BIOS. All you need to do is go into the bios screen. confim that it has seen your new memory and "save and exit" If it is not showing your new memory try removing and reinstalling the memory confirming it is installed correctly. it should just see it.
Jan 09, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 1100 won't read 512 Meg ram.
I had the same problem. I tried several brands of memory unsuccessfully, though they all guaranteed that their products would work with my machine. Finally, my brother (who works in IT) recommended that I go through The Upgrade Place (http://www.theupgradeplace.com/). Great price - less than half of what Dell charges - and the memory worked immediately upon installation.
When I told them that I had a Dell Inspiron 1100 laptop, they said that my PC required proprietary memory (which is true). I paid with a credit card and received the part two days later.
Good luck,
Jay DeKing
Dec 27, 2008 | Dell Inspiron 1100 Notebook
Dell memory Dimm B errors, 2 gig memory upgrade
Can your laptop support 2 gigs?
Also, are you using the right memory for your laptop?
Nov 15, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 1100 Memory speed
You need to look at the memory card(s) you have and only the same pin memory will install. Faster memory isn't as important as the maximum amount you can add, since your cpu can't run any faster, but windows can use the extra ram and avoid disk-swapping which is slow.
Nov 03, 2007 | Dell Inspiron 1100 Notebook
Black screen say unsupported memory , remove the unsupported memory from socket 1
I think you might have a faulty memory module. The socket where you push the PC card is not the Socket 1. I think the notebook is complaining about the Memory socket witch you can access if you remove the memory cover(click for details) on the bottom of the notebook. Try reseating the memory module, remove it from the socket and install back. Make sure the memory contacts are clean and not oxidized; clean them with an eraser if they oxidized. Try moving memory from one socket to another. If you have two memory modules installed, remove them one by one and test the notebook with only one module installed. Find out which module is bad.
Oct 19, 2007 | Dell Latitude C610 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
