Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
Add wireless router to my wired router 4 port (2 free ports) for my 2 laptops
Can I add a in line wireless to my Linksys model BEFSX41 there are 4 ports wireed in and working, only 2 are being used. Can I connect a wireless device to one of the free J45 outlets?
Terry
  • Belkin Master
  • 4,338 Answers
To add wireless to your wired router, you need an Wireless Access point. And when you get it you have to set the MAC address of the router into the Wireless Access point, in order for them to talk to each other. An Access point will probably cost you more than it would if you purchased a new wireless router. I would buy a wireless router, and sell the wired router on Craig's list or something.
Please remember to rate all users who assist you for free :)
Posted on Sep 30, 2008
  • JDTec
    JDTec Oct 03, 2008
    Did this solution help? Can I be of further assistance?
    P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
    • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
    • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
    • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
    • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
How can i find my security code for my linksys router
Manufacturer Model Protocol Username Password LINKSYS WAP11 MULTI n/a (none) LINKSYS DSL TELNET n/a admin LINKSYS ETHERFAST CABLE/DSL ROUTER MULTI Administrator admin LINKSYS LINKSYS ROUTER DSL/CABLE HTTP (none) admin LINKSYS BEFW11S4 Rev. 1 HTTP admin (none) LINKSYS BEFSR41 Rev. 2 HTTP (none) admin LINKSYS WRT54G HTTP admin admin LINKSYS WAG54G HTTP admin admin LINKSYS LINKSYS DSL n/a admin LINKSYS WAP54G Rev. 2.0 HTTP (none) admin LINKSYS WRT54G Rev. ALL REVISIONS HTTP (none) admin LINKSYS MODEL WRT54GC COMPACT WIRELESS-G BROADBAND ROUTER MULTI (none) admin LINKSYS AG 241 - ADSL2 GATEWAY WITH 4-PORT SWITCH MULTI admin admin LINKSYS COMCAST Rev. COMCAST-SUPPLIED HTTP comcast 1234 LINKSYS WAG54GS MULTI admin admin LINKSYS AP 1120 MULTI n/a (none) LINKSYS PAP2 / PAP2V2 (VONAGE) HTTP admin admin LINKSYS RT31P2 (VONAGE) HTTP admin admin LINKSYS RTP300 (VONAGE) HTTP admin admin LINKSYS WRT54GP2 (VONAGE) HTTP admin admin LINKSYS WRTP54G (VONAGE) HTTP admin admin
Jul 05, 2012 | Linksys BEFSX41 E Series Omniview Kvm 4...
I have problem connecting new computer to befsx41
1.Unplug the router for 1 minute then plug it back into the AC . Wait........ 30 second to see if you have acquired a signal
2. Confirmed that you have connectivity with the ISP ( internet service provider)
a.Check your wireless setup and see if the wireless is on.
b. do ipconfig / all
c. test the router by setting up the router by MAC address..
Jun 19, 2010 | Linksys BEFSX41 Router (DHBEFSX41)
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
How do I configure a BEFSX41 to be an access point (router only)? I've given up on using it to access the internet due to connection problems. I switched my Belkin 54G from an access point to the main...
If you have a modem and a router the two needs to have seperate Ip address. For exmaple I have a westell 6100 G modem with a wrt54g speedbooster router. I have my modem local ip set at 192.168.1.1 and my router local ip set at 192.168.9.1. I got my router on to do the dchp starting address with 192.168.9.15. Plug your cable from the modem into the wan port of the router and it sould work.
Oct 04, 2009 | Linksys EtherFast BEFSX41 Cable/DSL...
I HAVE FORGOTTEN MY NETWORK KEY FOR LINKSYS WCG200 ROUTER AND WANT TO ADD WIRELESS LAPTOP. hOW DO I FIND IT?
Put a direct line into the router and open an internet window. In the search bar type 192.168.0.1 and it should take you inside your router. you can see your password there
Jun 12, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
Trouble creating wireless access point from D-Link DI-514 router
1. Connect a pc to the router using a cable (wireless won't work)
2. Open a browser and type in: 192.168.0.1
3. Login with username: admin password: (blank)
4. Browse around the menus until you find a setting similar to "use as access point" and select it.
5. Save settings and log out.
6. Connect a cable from a port on your main router to this router's internet/wan port.
Dec 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
You should be able to plug the D-Link into any of the Linksys wired ports (not the Uplink port) and tell the D-Link to get an IP address from the Linksys router (as long as the Linksys router has DHCP turned on). Verify that both boxes are on the same network (192.168...) and don't have the same IP address. What happens when you do this? Can you get to the Linksys & D-Link from a wired workstation?
Dec 11, 2008 | IBM ThinkPad R31 2656 Notebook
I need to connect a real router with more ports to it 4-2 pcs
Connect the LAN port on the Barricade to the WAN port on your wireless router. The Barricade should be "plug-and-play",
i.e., no need to configure it. Similarly, the WAN port on the wireless-router is plug-and-play, so it should automatically get an IP-address from the Barricade.
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Then, start Internet Explorer, and connect to the web-server "inside" the router. Run the "Wired Network Setup Wizard", and then the "Wireless Network Setup Wizard". When you're done, then your "wireless" device(s) (iPod Touch, laptop, XBox360) should be able to make a wireless connection.
Note: no need for any CDs to "install" anything.
Sep 23, 2007 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Router/playstation 3
I reckon that you may need to configure your router to open ports to allow the internet traffic access. If you go to this link it will help you to configure the necessay "Port Forwarding" settings. http://portforward.com/english/routers/port_triggering/Linksys/BEFSX41/BEFSX41index.htm Are you connecting with a wired or wireless setup? Hope this helps - let me know if it does not
Sep 22, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
79 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
